Subject: is a 3 inch spacer lift by revtek enough for 33 12.50s for a 2002 trd
Chris___User is Offline
11/24/2003 4:37 PM
Just wondering how the revtek spacer lift is? Is it worth it. And can you run 33 12.50s on it with no rubbing???
Z___User is Offline
12/04/2003 12:19 PM
------------ chris at 11/24/2003 4:36:40 PM
With a lot of cutting you can get it to work, but don't plan on wheeling it. If you want a spacer lift, go with Cornfed. It's a higher quality than the Revtech, and it doesn't use blocks in the rear. Also, with 3" I'd stick with 32x11.5. You really need 6" for 33x12.5.
Forums > Vehicle Tech Talk Area > Toyota > is a 3 inch spacer lift by revtek enough for 33 12.50s for a 2002 trd
