Bryan___
| 01/02/2004 5:40 PM |
| I just bought a 91 4 runner 8 mounth ago and very happy with it. Runns great. But...I bought it whith a tick sorta futtering nois that still exist. I passed it off. Thingking and wandering if its normal? And do they all sound like that or is it a more serious problem? (crankshaft) Does any body know if I should be worried. thanx |
William_(rebel)___
| 09/24/1998 12:47 AM |
On 8/7/98 10:05:32 AM, Jody Campbell wrote:
> Welcome to the Toyota discussion forum, feel free to post any vehicle
> related comments or questions here!!! thanks
Jody, Rick, Tony
I have a Question. What are the best 1ton axles i could put under my 69 LC? |
Rick_Webster___
| 09/24/1998 11:51 AM |
Rebel,
I have a 74 TLC FJ-40. (It`s the one that you can see in the upper left hand corner of the web site!) The most common 1 ton axles are are the Dana 70 and Corporate 12 bolt(GM) axles. I`m sure Ford makes one, but I can`t think of it off hand. Your best bet would be a Dana 60 (Heavy 3/4 ton) and to cut the axles down about 2 inches on each side, unless you want the axles to stick out really far. The Dana 60 is a good choice because you can get lot`s o` goodies for it like lockers, stonger axle shafts, ring/pinion gears, etc. Any reason why you want a full one ton axle? Mud racing? If you must use a one ton, I suggest the Dana 70, it`s bomb-proof!
I hope that helps.
I have a Question.
Ryan_Lindstrom___
| 12/22/1998 7:19 PM |
Hey-
Sounds to me like you own a landcruiser. Torch off your spring hangers and perches and work up a link set-up. That`s probably about the easiest way to fix it. Locating your springs inboard on your axle a little further works too, but it isn`t really all that simple either. With a cruiser you really don`t have a whole bucket of options. I sprung mine over with stock springs and it ramped over a 1000 on a 20 degree ramp forwards and backwards. My tires hit the wheel wells, so without going wider I wasn`t gettin` any more flex. So--I`m goin` wider. You just about have to go spring over or go with like an Old Man Emu lift or something with maybe a little lower springrate. National Spring could whip something up for you that would probably work a whole lot better, but they don`t work for free either. Even with different springs though, cruiser rear ends generally just don`t work all that hot from what I`ve seen. Anyway---soups on, gotta go.
Later-
Ryan Lindstrom |
Rick_W___
| 02/08/1999 1:51 PM |
Please post your "want ad" type questions in the want ads section of our site.
Thanks,
On 2/2/99 10:19:07 AM, sterling Craig wrote:
> I`m looking for a 85 to 92 toyota 4runner for around 4500 has to be
> runnable and not trashy
looking on the outside will go up to 5100 if
> absolutely nessasary. |
Rick_W___
| 02/08/1999 1:52 PM |
Craig,
What size lift are you looking for?
Regards,
On 2/2/99 10:21:48 AM, sterling craig wrote:
> I`m also in the market to try and find a lift kit for a 4runner that`s not
> over $400. |
sterling_craig___
| 02/09/1999 10:33 AM |
On 2/8/99 1:52:23 PM, Rick W wrote:
> Craig,
Regards,
On
> over $400. |
sterling_craig___
| 02/09/1999 10:37 AM |
I`m looking for a 4" to 5" lift for a toyota 4runner for under $400.00
Thanks for any help,
Sterling Craig |
joe___
| 06/17/1999 9:07 AM |
> Craig,
Regards,
On
> over $400. |
unknown___
| 06/17/1999 9:08 AM |
Get a 4 wheel parts suspension there cheap go there web site 4wheelparts.com |
DRM___
| 08/13/1999 10:03 AM |
Call this place:
The 4xStore
615-791-1247
The are selling a folding rear shackle for LC`s that I have seen in action. A set for the rear is about $130, and just replaces your existing rear shackles. This would be the easiest way for you to increase your rear travel.
David
DRM033@aol.com
http://www.tennessee4x4.com/toyota
DRM___
| 08/17/1999 7:59 AM |
On 8/16/99 4:06:15 PM, Paul McEvoy wrote:
> I have a 1990 Toyota 4-Runner and I need a good suspension that I can pound
> into the ground and will not break....
Good luck finding that :) Everything will break, but I was very happy with the ProComp Stage I kit I had on my 90 truck. you have a different rear suspension, but they have one for your anyway. You could also look into the Stage II kit, or the Superlift kit - they are all basically the same 4" lift.
Stay away from the Rancho 3" lift - not enough height and poor design IMHO.
I also need a good lift kit that can
> lift my truck at least 7 more inches...
There is no 7" suspension lift availible for your truck. The best you can do is a 4" suspension lift (mentioned above) and a 3" body lift to get that height. That will let you run 35" tires and do good off-road.
David
DRM033@aol.com
david___
| 11/16/1999 6:22 PM |
| On 11/8/99 11:21:28 PM, Donovan wrote:
> 11/8/99 at 9.14p.m.Looking for 3" lift kit,Info how to or company name for
> 86 toyota truck Thanks |
unknown___
| 11/17/1999 11:39 PM |
On 10/22/99 12:03:11 AM, Mark Allen wrote:
> I have a `93 Toyota X-Cab 4WD with manual transmission. Often when I shift
> into second or third gear and I ease off the clutch slowly, I hear a
> strange noise that seems to come from the transmission. It is sort of a
> squeal, not high pitched, but very dull. It doesn`t last but a second or
> two each time it occurs. The clutch does not slip and seems to work fine.
> The truck has 120,000 miles on it. What do you think it could be?
IT COULD BE THE THROWOUT BEARING. BUT IF YOU FEEL A SHAKE OR WOBBLE IT MIGHT BE THE U-JOINTS |
DRM___
| 01/18/2000 8:57 AM |
On 1/16/00 9:35:12 PM, shooter wrote:
> I have a 87 toy. with a 3-inch body lift. does any one now what rancho 5000
> shocks ill need ? does it matter ?
A body lift does not change the suspension - you can easily use the recommended stock replacement shocks.
If you are looking for more suspension travel in the rear, it is best to fully articulate the rear axle and measure to figure out what shocks you need there.
But like I said - just ask for the Rancho RS5000 shocks recommended for a stock 87 Toy if you don`t feel like measuring.
David
DRM033@aol.com
http://www.tennessee4x4.com/toyota |
Art___
| 04/12/2000 12:24 AM |
IFS lifts are not cheap. To put together a true,full, everything together,holy-mackeral,gee-whiz 3"--4" lift, u r looking about $1200.00 good 'ole american dollars. UNLESS--- u r one hella'va fabricator,engineer,braided steel brake hose maker. I know , I done my homework. check out a company called JACK-IT ,out of utah. Look at their premium series....if not , get a downey catalog & get rear shackles and twist the torsion bars, they do work! or buy the 26mm torsion bars from downey if u feel u r going to screw your truck up.... |
Kevin___
| 01/22/2002 11:06 AM |
| i have a 95 4runner and i put on the 4" suspension lift and i followed it up with a 3" body lift.....i currently run 39x15.50 super swampers....thats correct....i have 39's on my 95 4runner with the ifs and they never ever rub. it looks awesome too...it had 4.88 gears which is good.....but i had to replace them.
George___
| 01/02/2004 10:32 PM |
| The 03 V6's make the tick and flutter noises also, so I guess it's normal if drunk on Saki. |
