Subject: FJ40 disc brakes - mini truck master cylinder?
4xguyUser is Offline
09/15/2004 10:54 PM
I now have 4-wheel disc brakes in my '75 FJ40, but stopping (even with power brakes) is a real chore. I simply can't lock up the brakes, or stop in a decent amount of time.
I heard a rumor that you can simply swap in the master cylinder from a '82 to '85 Toy mini truck with no modifications and that this will fix all of my problems. Is this true?
4XGUY
Jason Gorpman, Esq.
11/16/2004 11:53 AM
I figured it out. It turned out to be that the actuating rod between the brake pedal and the master cylinder was too short. Then I ran into another probelem with the brakes holding pressure after a while. Anyhow, the whole thing got fixed and now it stops on a dime!!!!
Jason Gorpman, Esq.
el_diabolicoUser is Offline
05/15/2005 9:21 AM
A proportioning valve is a must for rear disc conversions.
Colorado CruiserUser is Offline
05/24/2005 3:40 PM
use an fj80 master cylinder. Bolts right in. Has a larger bore and will run rear discs
05/24/2005 7:07 PM
I used a master cylinder from a mini truck and it works awesome too! I had to play around with a few different years to get the right bore / pressue / volume, but now I can stop on a dime.
...just another option.
rjblunkUser is Offline
09/08/2008 11:27 AM
Having the same issue - right now after putting on front and rear disc conversion for JT Cruisers my rear lock up without pressure on petal - any suggestions - I am looking at a proportioning valve. I have a master cylinder from an 86 Fourrunner on now.
"Fjtank"User is Offline
01/26/2011 11:14 PM
I like this
01/29/2011 11:27 AM
Later we found that the FJ80 master cylinder is the best solution. No more guessing, just bolt it in. See this: http://www.4x4review.com/Features/Tech/BetterBrakingforyourFJ/tabid/287/Default.aspx
Forums > Vehicle Tech Talk Area > Toyota > FJ40 disc brakes - mini truck master cylinder?
