Subject: Noise when accelerating.
Shawn___User is Offline
01/11/2002 12:51 PM
I have a 1999 Silverado with 39,000 miles. I got a noise when accelerating. The noise sounds like it's coming from the lower part of the engine or the transmission. The noise is a gargling sound. It just started a couple weeks ago and seems to be getting louder.
Any ideas?
Thanks.
03/14/2002 3:42 PM
------------ Try visiting the dealer and let them check it out. If they say nothing is wrong go to a person that knows something about trucks and let the person check it out but be careful who you choose!
Scott___User is Offline
03/14/2002 7:14 PM
------------ Shawn at 1/11/2002 12:51:12 PM
Any ideas?
Thanks. check the u-joints.
jack___User is Offline
09/13/2004 12:49 PM
b ------------ joe at 9/13/2004 10:49:10 AM
a
I3randed4LifeUser is Offline
07/11/2005 11:10 AM
Sounds like spark noc to me try a better gass other then regualar tons of trucks do it while under power
07/12/2005 7:53 AM
Any ideas?
Have you also checked fluid level in tranny? It is possible that it is low and the fluid is aerating and causing the noise.
07/12/2005 7:57 AM
Sounds overly simple, but also check that your lug nuts are tight.
ScottUser is Offline
02/14/2007 2:21 PM
Is your truck lifted?I had a problem with carrier bearing on mine. Only made noise when taking off.
Forums > Vehicle Tech Talk Area > Chevy & GMC > Noise when accelerating.
