Subject: Opinions on a late model Jimmy
brianstUser is Offline
02/15/2005 8:59 AM
My son is thinking of picking one up (2001 or 2002) and I was looking for some opinions.
Is it a Good/Bad truck, and what are the common problems I should look out for.
Thanks in advance
Brian
hvy55chvyUser is Offline
03/22/2005 5:49 PM
Im pretty close to getting a 00' blazer ZR2. Ive only heard good things about the 4.3 vortec. if going 4x4 its not a bullet proof trail rig but in moderate off road conditions it seems to be reliable. Im going off if several comments from friends that have run late model blazers and S10's and looking back on many off road club forum archives. I would be interested in hearing anything to the contrary from someone in this forum.
03/23/2005 8:17 PM
CAN YOU GIVE ANY SPECS. IT HAS?
03/23/2005 8:34 PM
Overview for 2002 Chevrolet Blazer
Model: Chevy Blazer LS (two- or four-door), Xtreme Body / driveline: rear-drive / four-wheel drive, front-engine Construction: welded steel, ladder type frame. Hot dipped steel, two-sided galvanized steel (on strategic panels) EPA vehicle class: compact sport utility Manufacturing location: Linden, New Jersey Key competitors: Dodge Durango, Ford Explorer, Jeep Cherokee, Jeep Grand Cherokee, Toyota 4-Runner, Ford Escape
Engine
Type Vortec 4300 4.3-liter OHV V6 (L35) Application: standard Block material: cast iron Displacement (cu in / cc): 262 / 4300 Bore x stroke (in / mm): 4.0 x 3.48 / 102 x 88 Cylinder head material: cast iron Valvetrain: overhead valve / two valves per cylinder Ignition system: direct Fuel delivery: sequential fuel injection Compression ratio: 9.2:1 Horsepower (hp / kw @ rpm): 190 / 142 @ 4400 Torque (lb-ft / Nm @ rpm): 250 / 339 @ 2800 Recommended fuel: 87 octane Maximum engine speed (rpm): 5600
Transmission
Five-speed manual 4L60-E Type: five-speed manual four-speed automatic Application: standard on two-door standard on four-door; Optional on two-door Gear ratios (:1): First: 3.49 3.06 Second: 2.16 1.63 Third: 1.40 1.00 Fourth: 1.00 0.70 Fifth: 0.78 — Reverse: 3.55 2.29 Final drive ratio:
Chassis/Suspension
Front: independent Short/Long Arm (SLA) front suspension computer-selected, friction-free coil springs (rear-wheel drive only) computer-selected torsion bars (four-wheel drive only) 35-mm stabilizer bar (with standard suspension) Rear: live rear axle and variable-rate, two-stage multileaf springs 23-mm stabilizer bar (with standard suspension) Suspension packages: touring suspension standard on 4-wheel drive models Xtreme Z87 Sport Suspension ZR2 Wide-Stance Sport Performance Package (Optional on two-door models only) Steering type: variable, integral power, recirculating ball Ratio: 16.13:1 Steering wheel turns, lock-to-lock: 2WD: 2- and 4-door 3.38; 4WD: 2- and 4-door 2.97 Turning circle, curb to curb (ft / m): 2WD: 2-door 34.8 / 10.6, 4-door 36.6 / 11.2; 4WD: 2-door 35.2 / 10.7, 4-door 39.5 / 12.0
Brakes
Type: power-assisted disc with ABS, front and rear Front (in / mm): 10.82 x 1.14 / 275 x 29 Rear (in / mm): 11.6 x .787 / 295 x 20
Wheels/Tires
Wheels: LS 2-door and 4-door: 15-inch aluminum 5-spoke wheel Xtreme: 16-inch deep-dish aluminum wheel Tires: Standard: P235/70R-15 all-season steel-belted highway radial-ply blackwall Optional: P235/70R-15 all-season steel-belted highway radial-ply white outline-lettered ZR2: 31-inch x 10.5-inch on-/off-road steel-belted radial blackwall Xtreme: P235/60R-16 Goodyear Eagle LS all season steel belted radial-ply
Dimensions
Exterior
2 door 4 door Wheelbase (in / mm): 100.5 / 2553 107.0 / 2718 Overall length (in / mm): 177.3 / 4503 183.8 / 4659 Overall width (in / mm): 67.8 / 1722 67.8 / 1722 Overall height (in / mm): 2WD: 65.2 / 1656; 4WD: 64.7 / 1643 2WD: 65.0 / 1650; 4WD: 64.6 / 1641 Track (in / mm): Front: 2WD: 55.0 / 1396; 4WD: 57.2 / 1454 2WD: 55.0 / 1396; 4WD: 57.2 / 1454 Rear: 2WD: 54.6 / 1388; 4WD: 55.1 / 1399 2WD: 54.6 / 1388; 4WD: 55.1 / 1399 Min. ground clearance (in / mm): 7.5 / 190 7.5 / 190 Ground to top of load floor: 2WD: 30.3 / 769; 4WD: 29.4 / 748 2WD: 30.0 / 763; 4WD: 29.4 / 750 Base curb weight (lbs / kg): 2WD: 3518 / 1596; 4WD: 3848 / 1746 2WD: 3671 / 1666; 4WD: 4049 / 1837
Interior
Seating capacity (front / rear): 2 / 2 3 / 3 Head room (in / mm): front: 39.6 / 1005; rear: 38.2 / 969 front: 39.6 / 1005; rear: 38.2 / 969 Leg room (in / mm): front: 42.4 / 1078; rear: 35.6 / 904 front: 42.4 / 1078; rear: 36.3 / 922 Shoulder room (in / mm): front: 57.7 / 1466; rear: 55.6 / 1413 front: 57.1 / 1450; rear: 57.2 / 1453 Hip room (in / mm): front: 52.1 / 1322; rear: 40.5 / 1027 front: 53.6 / 1361; rear: 51.3 / 1302 Cargo volume: Rear seat up: 29.8 / 845 33.6 / 952 Rear seat folded: 60.6 / 1717 67.8 / 1919
Capacities
Payload, base (lbs / kg): 2WD*: 932 / 423; 4WD: 1002 / 455 2WD*: 1329 / 603; 4WD: 1301 / 591 Trailer towing maximum (lbs / kg): 2WD: 5700 / 2585; 4WD: 5400 / 2449 2WD: 5500 / 2494; 4WD: 5200 / 2358 Fuel tank (gal / liters): 19 / 71.9 18 / 68.1 Engine oil less filter (qts / liters): 4.5 / 4.3 4.5 / 4.3 Cooling system (qts / liters): auto: 11.7 / 11.1; man: 11.9 / 11.3 auto: 11.7 / 11.1; man: 11.9 / 11.3
03/23/2005 8:36 PM
2002 CHEVROLET BLAZER OFFERS PROVEN CAPABILITY AND VALUE
Chevrolet Blazer, long a hardworking member of the Chevy Truck lineup, represents virtually everything a sport utility buyer could desire in an SUV.
For 2002, the Blazer will offer two versions: an LS model (two-door and four-door) in the standard configuration and the popular, sporty Xtreme (two-door). The four-door LT model is discontinued, but a leather-seating package is now offered on the LS.
With its capable Vortec 4300 V6, two transmission choices and the available Autotrac four-wheel-drive system on 4x4 models, Blazer can ably adjust to any situation that might arise on the road.
"Blazer’s role in the Chevrolet truck lineup has been slightly altered for 2002 with the introduction of the all-new TrailBlazer," said Russ Clark, Blazer brand manager. "We have simplified build combinations and model designations to offer Blazer buyers everything they could want in a compact sport utility vehicle, while offering them a lower price range."
Blazer is positioned between the Tracker and the TrailBlazer in the Chevy sport utility family, giving the division a comprehensive lineup of small to midsize utility vehicles. Clark added: "Blazer is a tried and true compact SUV that has experienced strong sales in recent years. With fewer model designations and a lower price point, we can draw even more consumers into the Chevy Truck family, while keeping our loyal customers."
Blazer Xtreme Last year, Chevy added the two-door, two-wheel-drive Blazer Xtreme to the portfolio. Xtreme blends an aggressive exterior appearance with a special Low-Riding Sport Suspension to bring a new attitude to the Chevy Blazer family.
Blazer Xtreme features: • Z87 Low Riding Sport Suspension
• Aggressive P235/60R16 Eagle LS low profile tires
• Xtreme deep-dish five-spoke aluminum wheels
• Lower body front fascia with fog lamps
• Lower body-side cladding and aggressive wheel flares
• Body-colored grille, bumpers, lower cladding and flares
• Special "Xtreme" badging
• Deep tint windows
• Leather-wrapped steering wheel
• Heavy-duty weight distributing platform hitch. Maximum towing capacity with manual or automatic transmission is 2000 lbs.
• Available sunroof
• Full range of audio systems available, including Bose Sound System and six-disc CD changer
Blazer LS
Blazer LS will be available in two- and four-door and two- and four-wheel-drive configurations. Each Blazer LS offers a convenience group with cruise control, tilt steering, power door locks and windows with electric remote heated exterior mirrors.
Blazer powerplant
Under the hood, Blazer’s highly capable performance comes from its standard Vortec 4300 SFI V6 engine that generates 190 horsepower @ 4400 rpm and 250 lb-ft of torque @ 2800 rpm. Two-door Blazers are equipped with a standard five-speed manual transmission or an Optional four-speed electronic automatic. When situations call for a little extra traction, the available Autotrac four-wheel-drive system automatically shifts power to all four wheels, as conditions require.
Fuel efficiency For improved efficiency, Blazer’s fuel management system includes a fuel filler assembly comprised of a multi-layer plastic fuel tank, revised fuel lines and vapor purge lines. Onboard Refueling Vapor Recovery (ORVR) compliance components are available for 2002 to help reduce unwanted emissions. To meet low-emission requirements in various states, a National Low Emission Vehicle (NLEV) system is also available on Blazer.
Safety and security In addition to its standard antilock brake system and front-passenger air bags, the 2002 Blazer features an Optional programmable auto door lock/unlock feature that allows customers to set the locking and unlocking functions to their preferences. On- or off-road, the Chevy Blazer is a confident performer, thanks to its standard Z85 sporty/firm suspension that accommodates a variety of driving needs.
Blazer for 2002 continues to offer a dependable, well-equipped compact sport utility that’s big on driving security in an insecure world.
03/24/2005 11:59 AM
sweeeeeeeeeeeet, that is specs. smart butt. but, that[banger]
03/24/2005 1:34 PM
Thought you'd like that. ;)
Forums > Vehicle Tech Talk Area > Chevy & GMC > Opinions on a late model Jimmy
