horsehauler
 Bone Stock Posts:3
| 02/23/2005 9:14 AM |
| just bought a new 2005 chevy w/duramax diesel. Is it normal for the oil pressure to fluctuate when letting of the gas?[:X] |
| 02/23/2005 9:39 AM |
How much is it fluctuating?
And, is it bouncing, or just lowering a bit when the RPM's come down?
horsehauler
 Bone Stock Posts:3
| 02/23/2005 9:52 AM |
horsehauler
 Bone Stock Posts:3
| 02/23/2005 9:53 AM |
| lowering a bit when the rpm's come down |
| 02/23/2005 1:38 PM |
This is pretty normal, as long as it's not dropping a lot.
If it drops a lot, you're truck will be [dead3] |
anthon9283
 Bone Stock Posts:7
| 11/20/2006 6:43 PM |
Hello,
I know this thread is old but I have a similar problem with my 2005 GMC 2500HD. At idle speed or letting go of the gas the oil pressure drops around 15-20 psi. It seems that about the same time my mileage went down considerably. Anyone have any idea if it is a problem and how to fix it? Thanks for your help.
Anthony |
| 11/21/2006 7:07 AM |
quote: Originally posted by anthon9283
Hello,
Anthony
Start will a fresh oil change. GM has had problems with leaky injectors in the past and when they do it delute crankcase oil and reduce pressure and MPG will drop too because of wasted fuel. If a fresh change restores pressure, you might want to get injectors check out but do change the oil now in mean time. I commend you for actually monitoring your gauges as many do not :} |
| 11/21/2006 10:09 AM |
quote: Originally posted by SnoMan
...I commend you for actually monitoring your gauges as many do not :}
Probably why they're called idiot lights. :) |
anthon9283
 Bone Stock Posts:7
| 11/21/2006 4:27 PM |
Hello,
Anthony
It happens with a fresh oil change as well. Another thing I noticed was that driving at say 55 mph and I let off the gas, the oil pressure drops down to 15-20 psi as well. I've had the dealership look at it and they said they replaced the sensor but still no luck. I'm not sure if it helps any but it is a 6.6L turbo diesel. |
| 11/24/2006 8:51 AM |
| I would install a manual gage and verify oil pressure readings. If they are that low there is a problem that should be covered by 100K mile engine waranty. Any chance that someone put the wrong oil in it? If they used 5w30 instead of 15w40 there would be noticably lower oil pressure in a warm engine. |
primetimek5
 Lift & Lockers Posts:537
| 11/25/2006 6:27 AM |
| its normal.
look at a forum called www.diesel place.com they have all the d.max info |
rick p. |
| 11/25/2006 4:36 PM |
quote: Originally posted by primetimek5
its normal.
I seriously question that it is "normal" |
| 11/25/2006 5:03 PM |
| I drive an '05 Chevy 2500 HD with the DMax and I only get a 5-10 p.s.i. drop (estimated). 20 p.s.i. is pretty substantial. |
anthon9283
 Bone Stock Posts:7
| 11/25/2006 11:49 PM |
I asked the members at diesel place and the two responses said it was normal. Still don't know if its normal or not. lol
| 11/26/2006 4:31 AM |
It may be a "normally" occuring problem but it is not "normal" to have pressure drop that much. Some of those members in that forum are so strung out on diesel hormones they think a lot of things are normal that really are not. |
| 11/26/2006 2:37 PM |
[quote]Originally posted by anthon9283
...Some of those members in that forum are so strung out on diesel hormones they think a lot of things are normal that really are not.
Now THAT was some funny sh1t! Funny, but sometimes very true. It's a bit of a cult-like thing. I think they may even have secret hand shakes. |
anthon9283
 Bone Stock Posts:7
| 11/26/2006 5:47 PM |
| Okay in my "official" GM service manual it say that the minimum acceptable oil pressure at a hot idle (680 RPMs) is 14 PSI (minimum, not normal) Minimum oil prseeure at 1800 RPM hot engine is 42 PSI and pressure relief valve starts to open at 64 PSI. If it is below these level GM considers it in need of repair but I consider 15 PSI to low for a diesel at a hot idle. |
anthon9283
 Bone Stock Posts:7
| 11/27/2006 4:44 PM |
| Is it possible for the relief valve to be stuck open? Or maybe some kind of malfunction with it? |
| 11/28/2006 6:48 PM |
| If it was stuck open, I would think that you'd have consistently low oil pressure...
SnoMan - what do you think? |
| 11/29/2006 4:07 AM |
I agree but it would likely be a lot less then 15 PSI at a idle if stuck open. There is another "valve" that controls spray for piston skirt areas, it opens at 29 PSI and allow oil spray above the main line pressure. If it was stuck open it could cause lower pressure too at a idle. I had a 2000 Dmax powered loaner van yesterday for a while and it idled at 25 PSI hot and it was 55 to 60 PSI cruising. It had no tach so I can provide no RPM data with pressures. |
anthon9283
 Bone Stock Posts:7
| 12/02/2006 3:17 AM |
hmm, I wish the dealer would have fixed this problem the first time I took it in. Think they were just giving me the run around.
This is what one of the diesel place guys posted:
"This is from a GM PI.
Condition/Concern:
The Engine Oil Pressure reading is low or near the red zone when coming to a idle.
Recommendation/Instructions:
Complete the current SI diagnostics for any trouble codes or symptoms found. If the customer concern is only the oil pressure gauge reading low, and they are comparing the reading to a older model diesel engine, compare the gauge reading to another 2004-2005 LLY diesel engine equipped vehicle. It is normal to see the oil pressure gauge near the red zone after running the engine and coming back to idle.
If the low oil pressure warning message/chime is on, follow the current SI diagnostics for Oil Pressure Diagnosis and Testing and/or the Engine Oil Pressure Gage Inaccurate or Inoperative. Complete necessary repairs using SI information.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed."
Also another person added that he changed the oil to Mobil 1 because of low oil pressure and that seemed to raise it. |
| 12/02/2006 8:24 AM |
| The problem is is that SI (I have it) says 14 PSI at a idle is acceptable.(likely to limit warranty claim on production tolerance issues) |
anthon9283
 Bone Stock Posts:7
| 12/03/2006 12:19 AM |
I agree with you there SnoMan.
I think I'll try a different oil and see what happens, if not it seems like its back to the dealer. |
