andy___
| 04/09/2002 2:11 PM |
| I am a newbie with at this so I need some advice. I have a '01 Sierra ExtCab 2WD SLE that I want to put a 3-inch lift on. I also want to get the largest tires that will fit comfortably and look good. As for tires, I want the BFG ATs, but not sure about the size. As for the lift, does anyone have any recommendations? Also, can I use the factory alloy wheels with larger tires or is there a backspacing issue? Also, since it is a 2WD, is a suspension lift worth it, or should I go with a body lift? I have heard of some issues with Body Lifts and Overheating on the 99-> GM trucks. Thanks in advanced. aczerlinsky@yahoo.com |
Erich_Heinzelmann___
| 04/16/2002 12:29 PM |
andy at 4/9/2002 2:10:36 PM
My advise is if your going to go through all that work to lift it, go six inches. You'll be able to fit 33's, but you'll have to buy new rims. A 3" body lift and a 6" suspension take about the same amount of time to install, and be prepared lifting a truck is not for the weak at heart. Be prepared to cut, gind, and drill if need be. Good luck
andy___
| 04/17/2002 7:25 AM |
Erich Heinzelmann at 4/16/2002 12:28:47 PM
Thanks for the advice!! |
Carl___
| 05/05/2002 10:03 PM |
body lifts aren't that hard to put on and they are relivively cheap. you could also check into a block/shackle lift in the back and a spindle lift in the front. those are relitively cheap also. i'm not sure if a suspension lift is your answer, they can get expensive. you can get 8 in wide rims fairly cheap as well, i wouldn't put 33's on stock rims, the handling may suffer greatly. and also i wouldn't go with the BFG at's if i were you. it all depends on what you want to do, but i've heard that besides sand they aren't very good for anything and have very low lateral traction. i just bought some 33 inch goodyear wrangler mt/r's and although pricey i think they're much more worth it.
andy at 4/17/2002 7:25:12 AM
