Subject: What is "Prerunner"?
Steve___User is Offline
04/17/2002 4:44 PM
I'm new to the offroad world, so can anyone explain to me what is "Prerunner"? Is it a type of truck, or type of offroading like rock crawling and mud boggling??? What are the different types of offroading? Thanks alot for any clarification.
ChvyAvalancheZ71___User is Offline
04/17/2002 5:44 PM
------------ Steve at 4/17/2002 4:43:44 PM
well the only prerunner i can think about is a toyota, its a tacoma that has a badge that sayd prerunner, dont know what the difference is between the tacoma and the prerunner though....prolly just a package that toyota has.... that is if this is the same prerunner ur asking about....
04/17/2002 5:57 PM
Yeah, I know about the Toyota, but I've read on other offroad sites, they mention prerunner, but they're not referring to Toyota. Like I've read one of the posting on this site that said something like, lifting a 2wd chevy truck will give it a prerunner look, I don't think they're referring to Toyota. There's no way a Chevy looks like a Toyota nor would it want to.
------------ chvyavalanchez71 at 4/17/2002 5:43:52 PM
C-Dog___User is Offline
04/24/2002 5:35 AM
A couple things:
A "Prerunner" is a term used for a two wheel drive truck that "pre-runs" off-road races, such as the Ivan Stewart Challenge (or similar). It is faster and cheaper to use this type of truck instead of the full bore race truck. Competitors are usually allowed to pre-run the race course in this type of vehicle only.
The Toyota Tacoma Prerunner is two wheel drive, and when equipped with the TRD package, comes with a locking rear differential (yes, on the two wheel drive) and full off road suspension. In theory, this truck runs faster than the four wheel drive (as mentioned above), and the rear locker can be used to get you out of slippery situations, should you get stuck.
Hope that helps.
------------ Steve at 4/17/2002 5:56:48 PM
04/24/2002 10:48 AM
Thanks for the clarification C-Dog. One last question, how does a rear locking differential get a vehicle out when it's stuck? It's still a 2-wheel drive vehicle, if the rear tires are stuck, the front tires would have to spin to get traction, wouldn't it? Thanks again.
------------ C-Dog at 4/24/2002 5:34:53 AM
A couple things:
Hope that helps.
Charlie_in_Alaska___User is Offline
04/30/2002 4:49 PM
because normally when you are stuck tecnacly only one tire will spin, and when you lockem in then you have both spinning. but pesranlly i think the 4x4 would work better. but that would help. my dad had a s10 that had a possy track and would lock in after 100 rotations of just spinning whithout grip and it was awsome to wach that little truck go. lol coundnt stop it.
------------ at 4/24/2002 10:48:01 AM
A couple things:
Hope that helps.
Forums > Vehicle Tech Talk Area > Chevy & GMC > What is "Prerunner"?
