Mike___
| 03/18/2003 6:45 PM |
Hi,
I have a 2002 2500 HD, i am not impressed with the front end sag. I was wondering if it would be worth turning up the torsion bars? I have heard both good things and bad things about doing this. If I was to crank up the torsion bars, how would i do that? Is buying a leveling kit a better option? What size tires would i be able to fit if I were to crank up the torsion bars? Thanks for your time and ideas, Mike |
SPYDER___
| 04/07/2003 9:30 PM |
Mike at 3/18/2003 6:44:40 PM
Hi,
I have a 2002 2500 HD, i am not impressed with the front end sag. I was wondering if it would be worth turning up the torsion bars? I have heard both good things and bad things about doing this. If I was to crank up the torsion bars, how would i do that? Is buying a leveling kit a better option? What size tires would i be able to fit if I were to crank up the torsion bars? Thanks for your time and ideas, Mike hey , i raised the front end of my 2002 2500 hd crew cab , i would say about 2 1/2 inches,but they can get higher,i did 2 1/2 to just level the truck , just cranking the torsion bars ,but you need to get a front end alinment the sooner the better ,ther is only 2 bolts,there about were the front door handled is butt under the truck ,2 screws hex nuts ,one on each side ,15 mm socket is all you need , (1) sit the truck on level ground ,same air presure on both tires,(2) measure from the ground to the fender on both front sides and just crank the bolts in ,same turns on each side ,they turn easy, you might need to just eye ball it,its easy ,and get a front end aliment, my rides dam good, i went from a 245/75r16 tire to a 285/75r16 with room for more,well let me know something at www.spycat61@yahoo.com |
Bill___
| 04/12/2003 7:30 PM |
spyder at 4/7/2003 9:29:46 PM
Hi,
Do you know how many times you turned the nuts? Is there any part of the threads still left on the nuts? Did you screw them all the way in? about how much was the front end alignment? Thanks |
