Subject: Powertrax Lockright- Removing C clip and axles?
Steve_B___User is Offline
09/06/2003 4:17 PM
I bought a complete rear end with a Powertrax lockright differential. It is out of an 88 2WD pickup. I'm putting it in my 91 K1500 4WD truck. I need to install the 6 lug axles from my truck into the new rear end. Just can't figure out how to get the C clips out.Been to powertax website. No info there. Anyone ever removed the C clips? hopefully the axles are the same dia and same # of splines. Any info appreciated.
Thanks!
10/10/2001 7:59 AM
------------ JD at 9/25/2001 11:54:40 AM
1991 2dr S10 Tahoe, 105K miles, dk blue, loaded with all pwr, sunroof, all records, 3 inch body, 3.5 inch fabtech with 32 x 11.50 BFG M/T. Must sell fast...asking 5550 OBO Atlanta area...
REDUCED TO $5000!!!
nick_rivera___User is Offline
12/10/2001 1:35 PM
------------ at 10/10/2001 7:59:28 AM
REDUCED TO $5000!!!
Can You send me some pictures
jason___User is Offline
12/13/2001 2:26 PM
do you have any pictures and will you email me the cerial number
Axle___User is Offline
09/08/2003 6:28 AM
Have some one push in on the axle (tire and brake drum removed) and it should slide enough for you to grab the "C" clip. If not then I think you need to remove the hub to give you some slack. i have helped some buddies out more than once and the one person pushing in on the axle as the other removed the clip always worked, so I have never had to go the other route. If this dosn't work hopefully someone will reply with a better way. ------------ Steve B at 9/6/2003 4:16:50 PM
Thanks!
Forums > Vehicle Tech Talk Area > Chevy & GMC > Powertrax Lockright- Removing C clip and axles?
