Subject: 6 inch bds lift 96 short bed driveshaft vibration
Karl___User is Offline
10/23/2003 11:43 AM
I installed the kit and Im getting a vibration from the rear driveshaft. I tried shimming the rear diff. but get the same results.I also put in new u joints in to. Can anyone help me on this one.
Nick___User is Offline
10/28/2003 3:15 PM
did you get new tires too? I sure you probably checked them for balance if you did, even if you didn't make sure a wheel weight didn't get knocked off. Another thing to check is if the rear drive shaft if it was removed and when reinstalled it wasn't put on the spline correctly so that the u-joints are opposing each other, if they are not this could cause a binding problem and vibration. try droping the transfer case down 1/2 to 3/4 of an inch no more this will help too.
good luck
------------ Karl at 10/23/2003 11:42:45 AM
Brad___User is Offline
10/30/2003 10:49 AM
10/30/2003 11:28 AM
i installed 6" pro comp on my 92 full size blazer,had a vibration also.had the driveshaft balanced,2 new ujoints,vibration 75% gone.Next thing i had to do was drop transfer case. what i did was i took the transfer case crossmember out and bolted it under the frame rail instead of where it was stock from factory.Had to tinker a bit to get it right.then i used spacers or washers between the transfercase and mount, played with it till i got the angle right. took a few test rides to getit.Now vibration 99% gone,only very slight vibration on take off, from 5mph to100mph 0 vibration .Now my truck rides like a dream better than stock GOOD LUCK
Forums > Vehicle Tech Talk Area > Chevy & GMC > 6 inch bds lift 96 short bed driveshaft vibration
