Subject: 4x4 auto push button engages by itself
staratakUser is Offline
06/06/2006 10:24 PM
I have a 2003 suburban and it shifts into 4x4 by itself. First, it started by going into 4 high - mostly upon backing out of a driveway. Then, I had the transfer case fluids changed and all checked out fine. About a week later, it started doing it again - sometimes it shifts into 4 low or into neutral - the service 4x4 light comes on. Once you get it into 2 wheel drive it goes ok and you turn off the vehicle, the light doesn't come back on. Any suggestions?
staratak
batchUser is Offline
06/07/2006 7:21 PM
The first thing to look at (and probably the cheapest) is the shift on the fly button itself. It is possible that you have a sticky contact inside the button.
Sadly, if it isnt that then I would probably suspect a short somewhere in the circuit.
06/08/2006 5:16 AM
I agree with replacing button as there has been issues with them.
06/08/2006 9:33 PM
Thank you to you both. I am hoping the button is the prob. - it's covered under warranty. i dropped it off to be diagnosed in the am - I will update and let you know what happened (maybe I'll even ask for donations ;)
Thanks again -
staratak
06/10/2006 8:12 AM
Good Call! It was the button - which was covered by warranty. However, because a new button was installed, the computer had to be reprogrammed to accept the button and the warranty won't cover that?!!!!!
staratak
06/10/2006 9:05 AM
Was that a GM warrantee or an aftermarket warantee?
If you have a GM warantee I would seriously suspect that the dealer is gouging money out of you. I cant believe that a GM warantee would allow for that.
If it is an aftermarket warantee the all bets are off.
06/10/2006 5:31 PM
I agree. Did you have a aftermarket custom tune? If so they would likely charge you to restore ECM programming. (if you have a aftermarket tune, ALWAYS remove it before warranty work.
tigerZ71User is Offline
04/09/2007 4:49 PM
I have the push-button 4x4 as well...when exactly should the "Auto 4wd" vs "Low 4wd" be engaged? Is "Auto 4wd" on the fly?...I'm new at this button stuff...
Ladies love country boys...
04/09/2007 5:24 PM
Well for 07 in GM truck it is now "twist and pray" because they are doing away with push button.
Forums > Vehicle Tech Talk Area > Chevy & GMC > 4x4 auto push button engages by itself
