Scott
 Bone Stock Posts:14
| 01/10/2007 3:29 PM |
| I have a 01 chevy 2500hd 8.1 litre. I am hearing a grinding noise from rear axle only when i take off slow. If I take off quick it makes no noise. It only happens when I first start to roll. Any ideas? Ps just bought the truck. |
| 01/10/2007 5:04 PM |
How many miles on it and have you ever checked or changed the lube in the rear axle? |
Scott
 Bone Stock Posts:14
| 01/11/2007 8:39 AM |
| 53000 just bought it so i dont know if its been done. Ill try that seems like a good place to start thanks snoman i'll let you know if that solves problem. Appreciate reply thanks |
| 01/11/2007 10:11 AM |
You might check pinion yoke Ujoint too. |
Scott
 Bone Stock Posts:14
| 01/12/2007 10:50 AM |
| thanks again snoman. I'll let you know the outcome. |
n/a
 Bone Stock Posts:11
| 01/23/2007 8:43 AM |
| yea check the joints because i have a 1995 z71 and it is making noise all the time bc i didnt take care of it right away the more you drive the worse it will get |
Scott
 Bone Stock Posts:14
| 02/12/2007 9:49 AM |
| Ended up being carrier bearing it was misaligned when lifted. Priblem solved. thanks snoman |
| 02/12/2007 9:59 AM |
Glad you hear you had a happy ending. Sometimes those two piece drive shafts with a carrier bearings can be a royal pain. With a lift you are really better off with a one piece one as it generally reduces ujoint angles. |
| 02/13/2007 8:51 AM |
You may need to consider a CV joint d-shaft if you go that route though.
Scott
 Bone Stock Posts:14
| 02/14/2007 2:04 PM |
| I had an 04 2500hd and it had a one piece aluminum driveshaft. Much better. Any idea on cost? With the 8.1 it puts a lot of torque and I can see the same thing happening again. |
