tpresnell
 Bone Stock Posts:14
| 07/26/2007 1:24 PM |
| What would cause my truck to constantly idle at around 1500rpm? Every once in a while the check engine light comes on but only briefly. |
| 07/28/2007 1:07 PM |
Can you tell us what the yr/make/model of your truck is? Also, the size of the engine, the number of miles, etc. would be helpful.
tpresnell
 Bone Stock Posts:14
| 07/30/2007 9:11 AM |
| It is a 95 chevy 1500 with a 350 about 140k miles |
| 07/30/2007 10:53 AM |
| Check gasket under TBI assembly between it and intake manifold. I had a similar problem on my 89 several years ago and it proved to be a bad gasket. |
| 07/30/2007 3:29 PM |
| I was about to suggest a vacuum leak as well. I'll bet Snoman is right. |
tpresnell
 Bone Stock Posts:14
| 07/31/2007 7:26 AM |
| What is involved in changing that gasket? Sounds like that could be a nasty repair. |
| 07/31/2007 10:29 AM |
Nothing to it. Simply removed TBI unit from intake. There is about 4 bolts holding it on and a few lines to disconnect and a few electrical connector too if you want to completely remove it from vehicle. There is a very thick gasket under it that is prone to fail with age. |
macabees34
 Bone Stock Posts:26
| 08/01/2007 10:22 AM |
| Also check those pesky plastic vaccuum lines coming off the TBI. I've had them crack or break and cause that too. |
oh ya!!!! From the macster!!! |
| 08/03/2007 10:03 AM |
yup - changing that gasket is a piece of cake.
Be sure to stuff some rags into the intake manifold so that junk doesn't fall inside there when you're working on it. Also, take a putty knife and clean any remenant gasket material off of the TBI unit and/or the manifold.
You should be able to do this in well under an hour, even if you've never done it before. |
