BAD86
 Bone Stock Posts:15
| 08/01/2007 5:52 PM |
| Is the only difference between a 208 T Case from a 400 and a 700R4 is the Input Spline?
If I use the input shft from the 700 will it fit in the 400 T case.?
Thanks |
| 08/01/2007 6:48 PM |
| It should. The next concern would be bolt pattern on Tcase where tranny bolts to it. |
| 08/02/2007 2:00 PM |
| Novak makes an adapter for that setup |
| 08/02/2007 2:41 PM |
| The only problem with any adapter is over all length. It may not be a issue here (length) but you need to be aware of it when you use most adapters. |
BAD86
 Bone Stock Posts:15
| 08/02/2007 4:43 PM |
| Thanks, So even if I change the input shaft i will still have to use a adapter?
| 08/02/2007 8:37 PM |
Not if the bolt pattern is the same. I am just not sure about that but my gut feeling is that it is different. |
| 08/03/2007 9:59 AM |
| I agree. I'm pretty sure that it's different, but I don't have my cheat sheet with me. |
