Subject: Gears
WestonUser is Offline
12/03/2007 5:22 PM
I have a 91 full size blazer o
12/03/2007 6:10 PM
Originally posted by Weston
I have a 91 full size blazer on 38's with stock 10 bolts. Currently building a 14 bolt/dana 60 set up what is a good gear ratio?
At least a 5.13. Even then with 38's it will only turning about 2100 RPM in OD which is pretty tall for that lift and tire size drag. A 5.38 would better (which is the deepest you can go in a 14 bolt anyway ) and do not let the deeper gear ratio is weaker gear set tale bother you. They will be plenty strong and axle shafts will fail before gears do.
12/03/2007 6:53 PM
x2 what snoman said
