Subject: 4x4 acting weird
zr2ssUser is Offline
01/12/2008 11:38 PM
I have a 1999 s10 zr2 and the
01/13/2008 5:45 AM
Okay the first thing to do here is to reset TCCM (Transfer Case Control Module) You do this by pulling the fuse and leaving it out for several minutes and then replacing it. This clears its memory of operation and position and loads new data. Sometimes this will fix it.
01/13/2008 11:13 AM
ok ill try that..i left it out for the night and it changed nothing..but maybe it was too long.i alsow replaced the relay and all 3 fuses..if their is no change what sould i go to next??? i really need help
01/13/2008 11:22 AM
Switch would be next choice as they are known to fail. If that fails then actuator. A dealer can scan for codes on it as they are not readable with normal OBD2 scanners. One last tip, if you wind up changing actuator, pull fuse when doing it because you should reset TCCM with a actuator change.
rob0722User is Offline
01/13/2008 1:24 PM
yeah, my dads '00 seirra did that, just blinked...I hear its a known problem. I got him a new switch and works fine, check ebay, or gmpartsdirect.com, or ckresto.com. or even pricegrabber.com.... dealer was priced crazy, check it out....
01/13/2008 2:58 PM
ok thanks guys i hope its something simple
01/13/2008 6:19 PM
It usually is on those vehicles. The vast majority of the time, it's electrical, and not mechanical (meaning a transfer case problem).
01/13/2008 9:06 PM
Well it kinda is a Tcase problem when encoder/actuator is bad.
01/14/2008 6:43 AM
Whatever... is there any post where you don't have to have the last word???
01/14/2008 12:05 PM
My we are short today. Your skin is too thin sometimes. The actuator is more or less part of Tcase.
highboy78User is Offline
01/16/2008 6:58 AM
hey man just had the same problem get your blazer off the ground beside the trasfercase theres a little motor that switches it that and the vacum line on the intake manafould check both of them they both where bad on mine good luck dude
01/17/2008 9:44 PM
Good tip highboy! Thanks.
