Subject: transformation of the 70 2wd
70chevydriverUser is Offline
03/14/2008 10:09 PM
I have a 70 chevy 1/2 ton 2wd,
03/15/2008 9:12 AM
Dont throw ANYTHING away until the build is complete. Other than that, you will probably be ok. Use new body mounts and bolts. Label all wires. Use ziplocs and a permenant marker to keep nuts and bolts in order. Save all usable parts, even if you think you might not need them. I am unsure of the body mounts lining up, so do some measuring before you tear into it.
03/16/2008 4:00 PM
Thanks a lot I have a friend that is helping me on this. He has switched bodys many times but not on different frames like this one will need.
03/16/2008 6:32 PM
I echo ChevyMan's comments on not throwing ANYTHING at all away from this project, until at least a few weeks after you've complete. Even within the first few days of converting, you'll probably ask yourself... "shiznit! What did I do with that wifflesnarget?" ;)
Forums > Vehicle Tech Talk Area > Chevy & GMC > transformation of the 70 2wd
