brianst
| 02/15/2005 8:59 AM |
My son is thinking of picking one up (2001 or 2002) and I was looking for some opinions.
Is it a Good/Bad truck, and what are the common problems I should look out for.
Thanks in advance
Brian
hvy55chvy
 Bone Stock Posts:6
| 03/22/2005 5:49 PM |
| Im pretty close to getting a 00' blazer ZR2. Ive only heard good things about the 4.3 vortec. if going 4x4 its not a bullet proof trail rig but in moderate off road conditions it seems to be reliable. Im going off if several comments from friends that have run late model blazers and S10's and looking back on many off road club forum archives. I would be interested in hearing anything to the contrary from someone in this forum. |
primetimek5
 Lift & Lockers Posts:537
| 03/23/2005 8:17 PM |
| CAN YOU GIVE ANY SPECS. IT HAS? |
rick p. |
| 03/23/2005 8:34 PM |
Overview for 2002 Chevrolet Blazer
Model:
Chevy Blazer LS (two- or four-door), Xtreme
Body / driveline:
rear-drive / four-wheel drive, front-engine
Construction:
welded steel, ladder type frame. Hot dipped steel, two-sided galvanized steel (on strategic panels)
EPA vehicle class:
compact sport utility
Manufacturing location:
Linden, New Jersey
Key competitors:
Dodge Durango, Ford Explorer, Jeep Cherokee, Jeep Grand Cherokee, Toyota 4-Runner, Ford Escape
Engine
Type
Vortec 4300 4.3-liter OHV V6 (L35)
Application:
standard
Block material:
cast iron
Displacement (cu in / cc):
262 / 4300
Bore x stroke (in / mm):
4.0 x 3.48 / 102 x 88
Cylinder head material:
cast iron
Valvetrain:
overhead valve / two valves per cylinder
Ignition system:
direct
Fuel delivery:
sequential fuel injection
Compression ratio:
9.2:1
Horsepower (hp / kw @ rpm):
190 / 142 @ 4400
Torque (lb-ft / Nm @ rpm):
250 / 339 @ 2800
Recommended fuel:
87 octane
Maximum engine speed (rpm):
5600
Transmission
Five-speed manual
4L60-E
Type:
five-speed manual
four-speed automatic
Application:
standard on two-door
standard on four-door; Optional on two-door
Gear ratios (:1):
First:
3.49
3.06
Second:
2.16
1.63
Third:
1.40
1.00
Fourth:
1.00
0.70
Fifth:
0.78
Reverse:
3.55
2.29
Final drive ratio:
Chassis/Suspension
Front:
independent Short/Long Arm (SLA) front suspension computer-selected, friction-free coil springs (rear-wheel drive only) computer-selected torsion bars (four-wheel drive only) 35-mm stabilizer bar (with standard suspension)
Rear:
live rear axle and variable-rate, two-stage multileaf springs 23-mm stabilizer bar (with standard suspension)
Suspension packages:
touring suspension standard on 4-wheel drive models
Xtreme Z87 Sport Suspension
ZR2 Wide-Stance Sport Performance Package
(Optional on two-door models only)
Steering type:
variable, integral power, recirculating ball
Ratio:
16.13:1
Steering wheel turns, lock-to-lock:
2WD: 2- and 4-door 3.38; 4WD: 2- and 4-door 2.97
Turning circle, curb to curb (ft / m):
2WD: 2-door 34.8 / 10.6, 4-door 36.6 / 11.2;
4WD: 2-door 35.2 / 10.7, 4-door 39.5 / 12.0
Brakes
Type:
power-assisted disc with ABS, front and rear
Front (in / mm):
10.82 x 1.14 / 275 x 29
Rear (in / mm):
11.6 x .787 / 295 x 20
Wheels/Tires
Wheels:
LS 2-door and 4-door: 15-inch aluminum 5-spoke wheel
Xtreme: 16-inch deep-dish aluminum wheel
Tires:
Standard: P235/70R-15 all-season steel-belted highway radial-ply blackwall
Optional: P235/70R-15 all-season steel-belted highway radial-ply white outline-lettered
ZR2: 31-inch x 10.5-inch on-/off-road steel-belted radial blackwall
Xtreme: P235/60R-16 Goodyear Eagle LS all season steel belted radial-ply
Dimensions
Exterior
2 door
4 door
Wheelbase (in / mm):
100.5 / 2553
107.0 / 2718
Overall length (in / mm):
177.3 / 4503
183.8 / 4659
Overall width (in / mm):
67.8 / 1722
67.8 / 1722
Overall height (in / mm):
2WD: 65.2 / 1656; 4WD: 64.7 / 1643
2WD: 65.0 / 1650; 4WD: 64.6 / 1641
Track (in / mm):
Front:
2WD: 55.0 / 1396; 4WD: 57.2 / 1454
Rear:
2WD: 54.6 / 1388; 4WD: 55.1 / 1399
Min. ground clearance (in / mm):
7.5 / 190
7.5 / 190
Ground to top of load floor:
2WD: 30.3 / 769; 4WD: 29.4 / 748
2WD: 30.0 / 763; 4WD: 29.4 / 750
Base curb weight (lbs / kg):
2WD: 3518 / 1596; 4WD: 3848 / 1746
2WD: 3671 / 1666; 4WD: 4049 / 1837
Interior
Seating capacity (front / rear):
2 / 2
3 / 3
Head room (in / mm):
front: 39.6 / 1005; rear: 38.2 / 969
Leg room (in / mm):
front: 42.4 / 1078; rear: 35.6 / 904
front: 42.4 / 1078; rear: 36.3 / 922
Shoulder room (in / mm):
front: 57.7 / 1466; rear: 55.6 / 1413
front: 57.1 / 1450; rear: 57.2 / 1453
Hip room (in / mm):
front: 52.1 / 1322; rear: 40.5 / 1027
front: 53.6 / 1361; rear: 51.3 / 1302
Cargo volume:
Rear seat up:
29.8 / 845
33.6 / 952
Rear seat folded:
60.6 / 1717
67.8 / 1919
Capacities
Payload, base (lbs / kg):
2WD*: 932 / 423; 4WD: 1002 / 455
2WD*: 1329 / 603; 4WD: 1301 / 591
Trailer towing maximum (lbs / kg):
2WD: 5700 / 2585; 4WD: 5400 / 2449
2WD: 5500 / 2494; 4WD: 5200 / 2358
Fuel tank (gal / liters):
19 / 71.9
18 / 68.1
Engine oil less filter (qts / liters):
4.5 / 4.3
4.5 / 4.3
Cooling system (qts / liters):
auto: 11.7 / 11.1; man: 11.9 / 11.3
| 03/23/2005 8:36 PM |
2002 CHEVROLET BLAZER OFFERS PROVEN CAPABILITY AND VALUE
Chevrolet Blazer, long a hardworking member of the Chevy Truck lineup, represents virtually everything a sport utility buyer could desire in an SUV.
For 2002, the Blazer will offer two versions: an LS model (two-door and four-door) in the standard configuration and the popular, sporty Xtreme (two-door). The four-door LT model is discontinued, but a leather-seating package is now offered on the LS.
With its capable Vortec 4300 V6, two transmission choices and the available Autotrac four-wheel-drive system on 4x4 models, Blazer can ably adjust to any situation that might arise on the road.
"Blazer’s role in the Chevrolet truck lineup has been slightly altered for 2002 with the introduction of the all-new TrailBlazer," said Russ Clark, Blazer brand manager. "We have simplified build combinations and model designations to offer Blazer buyers everything they could want in a compact sport utility vehicle, while offering them a lower price range."
Blazer is positioned between the Tracker and the TrailBlazer in the Chevy sport utility family, giving the division a comprehensive lineup of small to midsize utility vehicles. Clark added: "Blazer is a tried and true compact SUV that has experienced strong sales in recent years. With fewer model designations and a lower price point, we can draw even more consumers into the Chevy Truck family, while keeping our loyal customers."
Blazer Xtreme
Last year, Chevy added the two-door, two-wheel-drive Blazer Xtreme to the portfolio. Xtreme blends an aggressive exterior appearance with a special Low-Riding Sport Suspension to bring a new attitude to the Chevy Blazer family.
Blazer Xtreme features:
• Z87 Low Riding Sport Suspension
• Aggressive P235/60R16 Eagle LS low profile tires
• Xtreme deep-dish five-spoke aluminum wheels
• Lower body front fascia with fog lamps
• Lower body-side cladding and aggressive wheel flares
• Body-colored grille, bumpers, lower cladding and flares
• Special "Xtreme" badging
• Deep tint windows
• Leather-wrapped steering wheel
• Heavy-duty weight distributing platform hitch. Maximum towing capacity with manual or automatic transmission is 2000 lbs.
• Available sunroof
• Full range of audio systems available, including Bose Sound System and six-disc CD changer
Blazer LS
Blazer LS will be available in two- and four-door and two- and four-wheel-drive configurations. Each Blazer LS offers a convenience group with cruise control, tilt steering, power door locks and windows with electric remote heated exterior mirrors.
Blazer powerplant
Under the hood, Blazer’s highly capable performance comes from its standard Vortec 4300 SFI V6 engine that generates 190 horsepower @ 4400 rpm and 250 lb-ft of torque @ 2800 rpm. Two-door Blazers are equipped with a standard five-speed manual transmission or an Optional four-speed electronic automatic. When situations call for a little extra traction, the available Autotrac four-wheel-drive system automatically shifts power to all four wheels, as conditions require.
Fuel efficiency
For improved efficiency, Blazer’s fuel management system includes a fuel filler assembly comprised of a multi-layer plastic fuel tank, revised fuel lines and vapor purge lines. Onboard Refueling Vapor Recovery (ORVR) compliance components are available for 2002 to help reduce unwanted emissions. To meet low-emission requirements in various states, a National Low Emission Vehicle (NLEV) system is also available on Blazer.
Safety and security
In addition to its standard antilock brake system and front-passenger air bags, the 2002 Blazer features an Optional programmable auto door lock/unlock feature that allows customers to set the locking and unlocking functions to their preferences. On- or off-road, the Chevy Blazer is a confident performer, thanks to its standard Z85 sporty/firm suspension that accommodates a variety of driving needs.
Blazer for 2002 continues to offer a dependable, well-equipped compact sport utility that’s big on driving security in an insecure world.
primetimek5
| 03/24/2005 11:59 AM |
| sweeeeeeeeeeeet, that is specs. smart butt.
but, that[banger] |
rick p. |
| 03/24/2005 1:34 PM |
| Thought you'd like that. ;) |
