Subject: Any "bright" ideas?
09/28/2006 10:24 PM
My headlights have gone out!!!! What I have is a 1984 K5...all power (unfortunatelly). Anyhow, it all started when I hit the brights and everything went out...Well, with some fiddling with that lever, they came on. So I drove it like that for awhile...now my dillema is that they wont come on at all. Let me stress: this is not the headlight switch or wiring to it...but instead the brights lever on the column. How do I fix this situation? I suppose I will have to remove the steering wheel and the components behind it. I am not an electrician though....Anyone have any "bright" ideas????
09/29/2006 12:07 PM
replace the multifunction switch turn signal cam since you are their.
09/29/2006 12:37 PM
Good point PrimeTime.
ChevyMan - you'll need to replace the stalk and stalk switch to get the hi-beams to work again, and as PrimeTime mentioned, you should replace the cam while you're in there.
I'm a little surprised as I've never seen one of the hi-beam switches go bad on the stalk before, but hey... you learn sometime new each day.
Also, if you want to go on the super-cheap, you can buy a high beam foot switch at your local parts dealer for less than $5. You'll need to route the wires to and from, or pull them directly from the fuse panel, but it might save you $50-$100. Something to chew on.
09/29/2006 4:50 PM
Hey thanks for the info guys, I will remember to replace the cam. And to PrimeTime's comment,I think I will more than likely do that...as soon as I fix whatever is keeping my lights from coming on at all now. It did all satart with the high/low beam lever. So once I fix that, I assume that the high/low beam switch will more than likely be fixed anyway. I hope.......
09/30/2006 9:58 AM
just do a whole rebuild kit. turn signal cam, multi function switch & ignition switch
10/05/2006 12:00 AM
Do you by chance know where I can get that kit? I tried painless, with no avail.
10/05/2006 5:25 AM
you can pick up all those parts seprate from ur local parts warhouse. autozone, ooooorielys, advanced & napa tri napa first
10/07/2006 9:03 PM
Cool, thanks alot. I should have figured as much...I just hate electrical. You should see my wiring job for my KC 6x9s, lol total rats nest. Anyway, as always thanks alot for the help.
10/08/2006 4:50 PM
keep us posted---- good luck
Forums > Vehicle Tech Talk Area > Chevy & GMC > Any "bright" ideas?
