Subject: 07 chevy lift kits
JECUser is Offline
10/28/2007 9:57 AM
i have been trying to find a 6
10/28/2007 10:23 AM
It is not the autotrack. If is the different chassis and suspension used on that body style (coil over). A high lift must be done properly with a CV in front drive shaft because of higher drive shaft angle and the driveshaft being powered more often with autotrac. BTW, this will do wonder for you drive train warranty (not good)
JECUser is Offline
10/28/2007 12:58 PM
i was trying to get a fabtech or pro comp with no real luck. but i'm not sure what to do. is there one out there for my 07 sub? i need a lift that can handle 35x10.5-12.5x20
Forums > Vehicle Tech Talk Area > Chevy & GMC > 07 chevy lift kits
