Subject: Can I get 15's to fit on a fro
01/11/2008 12:28 PM
Hey guys, I need to know weath
01/11/2008 2:58 PM
The brakes are the problem for clearance. You could try to install smaller brakes but why would you want too with 42 inch tires?
01/11/2008 4:06 PM
They'll clear - I did it on my '74 Chevy 1 ton with a front D60. I had to take a lot of metal off, but it cleared. I ran it that way for another couple of years without problems, but I always wondered if the brake caliper would snap or not. I did it because I couldn't afford 16" rims at the time.
I don't recommend it for safety reasons, but it will clear.
01/11/2008 4:14 PM
Yea, I wont be driving it on the freeway or anything. It is offroad only. That is what I have been hearing, that you can grind the calipers down. I have just noticed that here in AK that 42s are cheaper in 15in rim pattern as opposed to 16in or bigger. Its not like I cant always get new calipers when I get a sweet deal on some new tires and wheels. Thanks guys.
01/11/2008 8:48 PM
The metal on the calipers are VERY thick, so there should be plenty of metal left when you're done.
For what it's worth, when I did it, I would take some metal off, then test fit the tire. I just kept doing that until it didn't rub anymore.
I did notice that when I was racing around (off-road of course) and jumping my truck, that it would rub - the rim would flex a bit. As such, I ground a bit more off of the calipers and all was fine.
01/12/2008 4:52 PM
Yep. That sounds right! That is what I did with my D44 and it worked good. Thanks for the help guys. I just wanted to know if it would be the same deal for the D60 as it is for the D44. I just did alot of work to my rig, I dont think I have showed ya'll pics of my shortbed lately. I will be sure to do so here soon. I chopped the bed down to the body line above the wheel well. Welded up my roll bar and made a spare tire carrier on it. Cut out the front fenders and competition cut the rear. And I am going to be adding a snorkel very soon. Then its all about beefing up the chassis and doing some skid plates.
01/12/2008 4:55 PM
yes, they will work. grind away
01/12/2008 4:58 PM
Sweet! Can't wait to see the pictures. RW
Forums > Vehicle Tech Talk Area > Chevy & GMC > Can I get 15's to fit on a fro
