Subject: Cherokee Check Engine Light
mountainwarriorUser is Offline
02/04/2005 8:43 PM
Has anyone had these problems? I bought a 2000 Jeep Cherokee Sport with the 4.0 I6 on 11/10/04 Check engine light has been on 12 times cylinder #3 misfire Check engine light was on 4 times O2 sensors 1) check engine light comes on after idling for 30-60 minutes and sometimes just comes on during normal driving 2) idles rough especially when cold 3) sometimes dies after start up 4) sometimes hard to start
11/12/2004 Replaced air filter Cleaned battery terminals
11/28/2004 Checked gas cap
11/29/2004 Replaced spark plugs
12/10/2004 Ran complete fuel system cleaner and octane booster through tank of gas
12/30/2004 Replaced coil pack Checked injectors replaced #3 injector and inspected injector wires
12/31/2004 Ran fuel stabilizer through tank of gas Installed heat barrier tape on injectors, fuel rail and intake Turned #3 injector to 2 o'clock position
1/03/2005 Replaced spark plugs
1/03/2005 Installed heat shield between intake an exhaust manifolds
1/04/2005 Dealer ran system diagnosis, unable to find any problems
1/05/2005 Dealer checked to make sure debris shield had been installed and checked codes, found no problem
1/19/2005 Dealer checked and found bad engine
1/20/2005-1/24/2005 Replaced engine (refurbished engine) Exhaust Repair
1/28/05 Dealer found O2 sensor bad
2/01/05 Dealer replaced both O2 sensors
2/04/05 Dealer found O2 sensors bad again
2/04/05 Dealer relaced both O2 sensors again Removed and cleaned out muffler
2/05/05 Replaced battery Replaced Thermostat
02/09/2005 7:08 PM
Wholly cow! Sounds like you got a "It's Friday and I'm ready to hit the bars" truck... or maybe even a "It's Monday and I'm hung-over like hell" truck.
By the way - how do you clean out a muffler?
02/13/2005 10:01 AM
I couldn't tell ya. I'm not sure what they did they just said they needed to clean the antifreeze out of the cat and muffler??????? But so far knock on wood the light has been off for 5 days.
4xguyUser is Offline
02/13/2005 5:02 PM
If you had antifreeze in your muffler and cat, then that means you blew a head gasket and antifreeze leaked into the engine and out the exhaust. While there may be some other way to get antifreeze into your exhaust system, I surely don't know.
Jason Gorpman, Esq.
02/15/2005 10:10 PM
Well Knock on wood or whatever the light has been off for a week[:D]
Angela0624User is Offline
06/10/2008 2:12 PM
I've got the same car. The dealership told us that theres a recall on the car, however Jeep isn't sure how to fix it so theres nothing they can do about it. Apparently the gas boils in the third chamber or cylinder. The car starts really rough and sometimes shuts off. Happens to me all the time in the summer, especially if I make a lot of short stops. I know this sounds rediculous but I don't put in SA gas and that seems to help some. Also, make sure the air conditioner is off before you start the car. As far as the check engine light, the gas cap is really sensitive. I've had that car in so many times for the check engine light and its almost always been the gas cap. According to the dealership it can take up to 40 starts for it to turn off. Good luck.
06/10/2008 8:55 PM
That's really great information Angela, thanks!
What do you mean by "SA" gas?
Triumph19User is Offline
06/16/2008 12:58 PM
I seem to be having the same problem with my 2000 Jeep cherokee. Engine light is on and the codes say it is a mis-fire. Starts up OK but halfway through the warm up its starts to rock & roll to the point of almost stalling.After it is fully warmed up it smooths out somewhat but its still not perfect ... seems to be idling too low. Many mechanics have had their hands on this car but so far none have been able to fix it or even know really what the problem is.
Does any one have any suggestions...this is driving me nuts!
Mike James
Forums > Vehicle Tech Talk Area > Jeep > Cherokee Check Engine Light
