Subject: jeep yj 1993 4x4 problem
dodgechargerUser is Offline
12/09/2009 9:08 PM
Hi here's my problem I don't know what's wrong with my 4x4 but it doesnt work
issue is my light in the dash doesnt come up anymore
my two front wheels are not getting traction
my shifter for the 4x4 works fine
2 wheel drive and 4 high are the same when I shift
when I put on 4 L my motor is reacting like it should be doing
im wondering what could be the cause
anyone ?
12/12/2009 9:18 AM
Hi DodgeCharger - have you done any diagnosis work on the truck yet?
Here are some things to check, so that you can isolate the problem:
  1. Have you checked to see if it the light bulb is burnt out?
  2. Have you checked to see if the front driveshaft is engaged when you select 4-hi or 4-lo?
  3. If you have manual locking hubs, are they fully turned and engaged?
IndyToyUser is Offline
12/12/2009 3:24 PM
What kind of jeep and the year and drive train?
MIDWEST4X4.US
12/16/2009 5:21 PM
1.Have you checked to see if it the light bulb is burnt out? light bulb is fine
2.Have you checked to see if the front driveshaft is engaged when you select 4-hi or 4-lo? it doesnt engage thats the problem
3.If you have manual locking hubs, are they fully turned and engaged? no manual locking hubs locking is done by my shifter inside jeep used to be working now stopped
brought it to my mechanic had a hole in my hose plugging for the vaccum box but its repaired but not working more
12/16/2009 6:13 PM
jeep yj 1993 i dont know which drivetrain it is stock one I guess
12/17/2009 9:44 PM
It's the actuator then. Check the vacuum lines again (like your mechanic did). If that's good, then you need to replace the actuator.
burtonjuelfsUser is Offline
06/08/2011 4:54 AM
a 93 jeep yj with 4.0 and ax-15 tranny. the jeep has 4inch lift w/t-case drop and with 33inch A/Ts. when its driven in 2wd on pavement/offrd it makes a clunking sound which doesnt sound severe until put in 4wd. the vacuum disconnect isnt hooked up and it doesnt look like the previous owner put TJ shafts on it. but anyways when its shift to 4wd and try to turn or drive it slowly straight the clunking sounds is very loud and sounds like "someone is banging the crap out of the jeep underneath with a hammer" well anyways it does feel like the front wheels grab when i turn on pavement but maybe its just the tires. is this a tcase problem, ujoint problem, or what. thanks.
rimadyl for dogs cheap
Forums > Vehicle Tech Talk Area > Jeep > jeep yj 1993 4x4 problem
