Subject: Vapor lock?
scotte___User is Offline
04/20/2002 7:15 PM
I have a problem with my fuel delivery. I have a glass fuel filter and pressure guage on the line and when i first start it up i have 5 psi. But after the engine heats up the pressure drops down to about 1 to 2 psi and fuel is barley going through the glass filter. anyone seen this? I just put the new Holly Truck Avenger carb and electric fuel pump on my 85 Jeep that has a 350 in it. Any input to this problem would be appreciated. thanks scotte
Tom_Houston___User is Offline
04/24/2002 3:59 PM
The only time I have seen this is when the strainer in the tank gets plugged.
Tom Houston Loveland, Colorado
------------ scotte at 4/20/2002 7:15:04 PM
tanman___User is Offline
05/19/2002 10:05 PM
------------ scotte at 4/20/2002 7:10:59 PM
Vaporlock is when the fuel bols befor it reaches the motor and enters as a gas(literaly) This is bad
Liberty___User is Offline
09/17/2002 10:47 PM
"Vapor Lock" has also been used to describe what happens when you get water in the air intake. The water gets vaporized in the engine and causes many bad things to happen to the engine.
