Subject: trailer wireing harness
grumpydawgUser is Offline
04/18/2005 12:44 PM
I bought and installed thr e "correct" hoppy wireing kit on an '94 cherokee and it don't work right.
i tried the toll free hot line on the pack, get voice mail but never any return calls.
tried the web site, no help there either
tried the "pros" at autozone, got blank stares and 'huh?'
yes i put in in correctly, the plugs only fit one way.
yes the lights are wired correctly on the trailers, tried them on 3 other veichicals
should i just scrap the correct kit and wire it my self?
when in doubt use duct tape
04/18/2005 10:51 PM
What is a hoppy wiring kit?
04/19/2005 9:58 AM
made by hopkins (i think that's the co. name), found at auto zone type stores, wally world, kmart, ect. has a picture of a kangaroo on it.
usually there stuff is good, i don't know if i got a bad one or what
Rob StapletonUser is Offline
04/19/2005 11:11 PM
I'm not a trailer wiring guru but I believe the 94 Cherokee has the amber turn signals. If thats the case you may need another adapter to make it work with that type of system. Most cars use the same bulb as the brake Light for the turn signal. Hope this helps.
Special Thanks To: 4X4REVIEW.com Blue Torch Fab BFGoodrich Warn
04/19/2005 11:32 PM
the wire kit came with the 'tail light converter' and yes i hooked it up also
04/20/2005 12:01 AM
It could be that you have a bad harness (it might have been incorrectly manufactured).
You said that it wasn't working correctly - what is doing wrong, or not doing at all?
04/20/2005 6:57 AM
turn signals and brake lights work fine untill the running(tail)lights are turned on then only have running lights on trailer
Forums > Vehicle Tech Talk Area > Jeep > trailer wireing harness
