Subject: Bad carb?
dave_Daley___User is Offline
12/03/1998 9:47 PM
My 84 Cherekee 4 cyl wont run right. when i first start it it will run good for about 2 mile miles. Can run through the gears at full power. Then it will loose power and hardly run. I tried turning up the idle screw and it will only idle for a short time than stall. The 84 only has a module and no computer. Is this a module or carb problem?
