Subject: jeep wrangler shake
karin___User is Offline
08/06/2003 8:55 AM
I have a '94 wrangler. At speeds over 60 or so, if I hit a bump I get a really bad side-to-side shimmy or shake. If I let off the gas this goes away in a few moments, but it's a little scary while it's happening! I heard once that this was caused by a part unseating, and that the shimmy lasted as long as it took the part to re-seat. Has anyone heard of this?
Frank_Di_Piazza___User is Offline
08/31/2003 7:29 PM
I have a 94 Cherokee that does the same thing! It is terrifying. How ridiculous! Does anyone have an answer? ------------ karin at 8/6/2003 8:55:25 AM
Stephen___User is Offline
09/02/2003 7:20 PM
Check your steering stabilizer, like a shock absorber, fronte end bushings, and well, tire balance
Adrianna___User is Offline
09/19/2003 8:27 PM
I may have the answer to your shaking problems. It might be the steering damper. I have an 1989 Jeep Wrangler that would shake violently while driving at speeds over 50 mph. But only when driving straight, corners were fine. It was the steering damper which acts as a steering stabilzer and it looks like a horizontal shock. I had a new Monroe steering damper installed for under $70.00 and I was back in business.
Good luck.
------------ Frank Di Piazza at 8/31/2003 7:29:03 PM
Steve___User is Offline
09/23/2003 10:53 AM
AKA "Death Wobble"
Here's a great article on that... A little older, but worth the read. http://www.off-road.com/jeep/tech/deathwobble/
Like the others in this thread have said, replace your steering damper and get your wheels and tires looked at (I had a VERY small ding in one of my wheels that was contributing to the problem.) I just bought a new damper for 40$ and put it on myself with very little effort. It helped a lot.
Steve
Forums > Vehicle Tech Talk Area > Jeep > jeep wrangler shake
