david___
| 01/25/1999 3:03 PM |
| I have a stock 1970 CJ5 that I would like to put a Superlift SuperRide 2.5" lift on. I would like to know what type of backspacing is needed to limit the rubbing of tires on the inside of the wheelwell for 31X10.50 tires. Also, I don`t have a pitman arm on my steering, so will the new suspension cause a problem with the steering. Finally, will the lift have a bad effect on the driveline angle since the CJ5 has a short front drive shaft? Thanks. |
