Steve___
| 11/24/2003 9:33 AM |
| When backing up or accellerating after a stop, I hear a grabbing/binding sound from rear wheels. I also hear it when making hard left turns. It does not make any noise when wheels are cold, but after driving for a little while, it will make the noise almost everytime. Any ideas? |
joe___
| 11/29/2003 1:48 AM |
If you have already checked the brakes and eliminated that, one thing you could check is the rear differential fluid. If you have a limited slip differential, it may need some limited slip additive. If you do not have a limited slip diff, that will not help you though. It could also be a wheel bearing going bad. Check to see if any diff fluid is seeping from around the axle seal. If it is, you could need a new axle bearing. They are real easy to change in the rear axle. Don't forget a new axle seal too.
Steve at 11/24/2003 9:33:12 AM
