Subject: locking hubs
Aaron___User is Offline
03/15/1999 9:47 PM
I`m planning on putting a 2" body lift on with 30x9.5" tires. I want some extra help in the mud. I am looking into a locking differentials. I`m gonna put one in the rear first since I`ve heard not to put one in the front unless you do some serious offroading. I don`t know which brand to buy, and I also want to know what kind of problems people are having with them if any. Right now I`m leaning towards the Power Trax Lock Right which is automatic instead of a manual locking diff. I want as many opinions as possible, because I want to make the best decision for my Jeep,
Carl___User is Offline
09/28/1999 6:47 PM
On 9/24/99 11:31:13 AM, Mo wrote: > On 9/23/99 9:13:22 PM, Carl wrote: > i have an 85 cj7 and was trying to > figure out which side the short end of > the front drive shaft goes to? > the Transfer case or the diff. Does anyone > know? I have seen it both > ways and was wondering if anyone knows which is > > right. carl
Carl,
Here`s how I do it: [No, I`m no artist]
T = > transfer case yoke U = U-joint D = Driveshaft, big side d = Drive shaft, > small side A = Axle yoke
T A TUDDDDDDDDDDDDD > UA TU dddddddddddUA TUDDDDDDDDDDDDD UA T > A
Logic: Big side is (should be at least) higher > than the small side, so water is less likely to sit on that seal and > penetrate to the inside of the shaft.
Mo
the only seal on the drive shaft is on the short side.
carl
