Norris___
| 05/18/1999 7:24 PM |
rebuilding the Carter BBD on my 89 Wrangler helped with the clogged idler tubes, but now, over night the Float Bowl will empty of gasoline. Where is the gasoline going????/ Could it be leaking back into the fuel line, or could there be a vacuum pulling it into the manifold ?? Once I get the floats floating again, she will run fine, although the idler tubes still drip drip some :( Think i may have trash in the 10 year old tank, will drop it after this tankfull to see.
How about the vanishing gasoline???? any suggestions? |
