Subject: no brakes after 2.5" lift !?!
Mike___User is Offline
09/26/1999 5:17 PM
i recently lifted my 80 cj 7 with a 2.5" rancho system. i bought the new brake cables, frame to caliper, and after bleeding the brakes i can barely stop. i replaced the booster, the master cylinder, and built a tool to hold the little pin in on the distribution block behind the drivers front fender. i have no leaks on any lines and no bubbles in the system. everything i did was simple mechanics. the brakes worked fine before the lift too. any help on this problem would be greatly appreciated.
mike
Forums > Vehicle Tech Talk Area > Jeep > no brakes after 2.5" lift !?!
