Subject: 90 Jeep yj
odell87User is Offline
04/21/2008 6:35 PM
I have a 2.5 4 cylinder engine. When I pull the number three plug wire off the engine runs the same. At idle it runs rough. Could use some help I am kinda stumped here. Thanks
Dan PittsUser is Offline
04/21/2008 6:47 PM
number 3 is a dead cylinder. this being that u probably need either a plug or a wire that simple.
04/22/2008 3:56 PM
well, there could be another issue here at play. Since it's an 18-year old vehicle, there is a possibility that you could have a dead lifter (hydraulically speaking of course), or a lobe on a cam that is shot too.
In the end, it may not just be electrical, it could be mechanical.
Regardless, I would first check to make sure you're getting spark at that cylinder.
