Jacob___
| 06/08/2000 6:02 PM |
| is there any quick and inexpencive ways to fix a radiator leek. i can't find where it is leeking from yet. but all the fluid is definetly out. |
Ted___
| 06/09/2000 10:24 AM |
Your local parts store will have several different types of stop leak. There is the liquid stuff that looks like a lumpy milk shake to the solid stuff that looks like powdered aluminum. I have used both. The liquid never worked too good for me but the powder works great. Both are meant to be only temporary. Are you sure it the radiator and not the hoses? I don't think the stop leak will work to well on hoses.
jacob at 6/8/2000 6:02:26 PM
MIKE_B.___
| 06/12/2000 12:31 PM |
If you want to go the easy way, there's a product called Bar's Leaks that can be found almost anywhere( parts stores, Wal-Mart, K-Mart, etc.) that works very well at plugging even holes big enough to stick a #2 pencil in. The only drawback in my opinion is that if it'll plug a leak, it may clog your radiator as well.
MIKE_B.___
| 06/12/2000 12:33 PM |
If you want to go the easy way, there's a product called Bar's Leaks that can be found almost anywhere( parts stores, Wal-Mart, K-Mart, etc.) that works very well at plugging even holes big enough to stick a #2 pencil in. The only drawback in my opinion is that if it'll plug a leak, it may clog your radiator as well. By the way, is there any water coming from your exhaust? You could have a blown head gasket as well.
