PWhite
| 12/02/2007 3:52 AM |
| I have a 1993 wrangler with a |
| 12/02/2007 5:46 AM |
| Not sure what you hope to gain with this swap. You will not pick up any usable power or torque increase and will actually see a bit less torque at lower RPM's. Plus that engine was never in a Wrangler and bell housing bolt pattern is wrong too. (if Dakota is a manual and Jeep is too you could adapt Dakota bell housing to your Wranglers tranny) If you have your heart set of a V6, I would adapt in a GM 4.3 and it would give you a noticeable usable power and torque increase. The 4.3 used same setup as a GM 350 (same block minus 2 cylinders) so there is a lot of parts out there for swap. One more thing, a AMC 304 or 360 (not a Dodge 360) will bolt up to current bell housing and would be a fairly easy swap too. (CJ even had a V8 option too in late 70's through early 80's) |
| 12/02/2007 9:43 AM |
| I agree - the V6 Magnum should have been called the .22 caliber. ;) |
sammy 87
 Street Queen Posts:107
| 12/04/2007 3:27 PM |
| your strait 6 is the highout put too i hope its locked up and thats the reason why you want to swap |
| 12/04/2007 5:35 PM |
Even if it is, get another one, the Dodge V6 would be a down grade and not a easy swap either. |
| 12/04/2007 7:19 PM |
You could always be a real hero, and put a Cadillac 512 in it. :)
Do that, and I'll put you in the magazine.
