Subject: jeep grand cherokee whining from front wheels
User is Offline
10/31/2008 2:45 PM
can some one help me i have whining noise at front wheels sounds like tyres or wheel bearing woorse between 50 and 55 does not alter sound pitch if u go faster or slower eny ideas thanx
11/01/2008 12:08 AM
Is it more of a high pitched squealing sound? Does it sound metallic?
schoonerUser is Offline
11/03/2008 12:57 PM
no its not metallic sounds like small stones stuck in tread but noise does not change at different speeds noise not so loud on rough surfaces tryes got approx 3mm tread left eny ideas thanx
11/03/2008 1:46 PM
Hmmm... could you have gravel inside your rims by any chance? Or, perhaps, some mud on the inside edge of your rim that the brake caliper is rubbing on?
YJ93User is Offline
11/04/2008 8:45 PM
try rotating the tires to rule out the tires
11/06/2008 1:06 PM
thanx rotated tyres i know this sounds funny but on stock firestone tyres do the rotation arrows all have to point clockwiseomn all 4 wheels thanx again
YJ93User is Offline
11/06/2008 11:26 PM
you can still move the front left to rear left and front right to rear right.....sometimes on 4wheel drives the front tires will wear uneven and cause noise and vibration....it might be worth a shot
11/07/2008 6:50 AM
thanx all for your help nice to know peaple who experiance these problems
11/09/2008 12:16 PM
You're welcome! Be sure to drop us a note if you still have problems, and also be sure to let us know if you find out for sure what the problem was, so that others may learn from it too.
thanks,
11/15/2008 2:53 PM
hi guys as advised by u i swopped the wheels around and it seems much better as i was getting low on tread intend fitting new tyres to the front and that shoud crack it many thanx again
Forums > Vehicle Tech Talk Area > Jeep > jeep grand cherokee whining from front wheels
