Subject: Long Arm Suspension
rdjsgaylorUser is Offline
11/26/2004 11:49 AM
I am in the market for a long arm susp. for a 04 unlimited.
my research is leading me towards Full Tractions system. Does anybody have pros/cons for any 6" systems?
11/26/2004 5:11 PM
Are you dead-set on a 6" lift kit?
11/27/2004 8:12 PM
Absolutely not. The only thing Iam set on is a quality lift.
My reason for 6" lift is to accomidate a 35" tire.
stagewestUser is Offline
11/29/2004 12:35 PM
You might also check out the Teraflex LCG kit. I think it is the best kit on the market now and have several customers that agree. It is a 4or5 inch. kit and requires a one inch. body lift. http://www.teraflex.biz/index2.htm http://www.stagewest4x4.com/store2/store/comersus_viewItem.asp?idProduct=4678
Joel Snider Stage West 4-Wheel Drive Center 6700 Hwy 82 - Glenwood Springs, CO 81601 - PH: (970) 945-5227 http://www.stagewest4x4.com 4by4@crimsonwireless.com
11/29/2004 12:51 PM
I would agree with Joel. There are a few long-arm kits on the market, but the LCG kit is worth ever penny and then some. I've ridden / drove about 5 different types and the difference is night and day!
sublmnl1990User is Offline
11/30/2004 7:23 PM
I would check out this link these are very well made http://www.rubiconexpress.com/dynamic/mainpage.asp?folderid=1601
oops go to stagewest
JeeptrekkerUser is Offline
12/01/2004 9:25 PM
I have the Rubicon Express 3.5 in. SuperFlex kit and am very happy with it. Full Traction also has a good reputation. Their kit eliminates the rear track bar but as a result, costs more.
2003 Rubicon, RE 3.5 SF, 12.50X33 Trxus, Jeeperman rear and skids, Hanson front, Warn winch, Nth Degree engine skid 82 CJ-7, 87 XJ, Rebuilding 55 CJ-5 Las Cruces Four Wheel Drive Club SWFWDA, UFWDA
Joel77User is Offline
12/07/2004 1:19 PM
By far the best long arm kit is Full Traction, their engineer is considered the best in the industry.
The only other susp. for 35" tires is the Currie J-arms, but it´s not bolt on.
Joel
Forums > Vehicle Tech Talk Area > Jeep > Long Arm Suspension
