Subject: weird tranny stuff
jd___User is Offline
05/29/1999 2:10 PM
I have a 1990 ramcharger with 360 and auto trans. sometimes the speedo stops working and the overdrive kicks off. The transmission was rebuilt ($2900.00) but the proble still exists. Any help out there?
russ___User is Offline
04/17/2000 9:14 PM
sounds to me like your speed sensor on the side of the transmission has gone bad replace it and your problem should go away. ------------ jd at 5/29/1999 2:10:09 PM
cwby_ram___User is Offline
12/04/2003 10:02 PM
I just had my speedo cable replaced. My '95 Ram was doing he same thing, had to drive for a month with the OD turned off. Get that speedometer cable replaced! ------------ russ at 4/17/2000 9:14:21 PM
03/10/2004 3:11 PM
I HAD THE SAME PROB ON MY my 91 its the speed sensor on the transefer case
