Subject: Transfer Case Trouble
RocksterUser is Offline
05/02/2005 2:14 PM
Any ideas what would make the transfer case in my '98 Dodge Ram 2500 pop out of 4 Lo when ever the truck hits a bump? If I get a little hop from axle wrap or from hitting a hole, it pops right out of 4 Lo. Truck has 130K miles and I am the 4th owner. When I changed the fluid in the T-case a little while ago, the ATF looked normal and there was no evidence of metal or sludge. Linkage does not appear bent or excessively worn.
05/02/2005 2:25 PM
Is it a lever-type shifter on your truck, or an electronic-push-button style?
05/16/2005 4:34 PM
Regardless of type it sounds like linkage because electric of manual the linkage controls the engagement of it and a bump shakes it enough to let it pop out. Check linkage adjustment.
05/17/2005 12:29 AM
Sorry about taking so long to reply...been out of touch for a few days. It is a lever type shifter for the T-Case. I've got to see if there is some adjustment I can make for the 4-Low position. Thanks for your thoughts.
Forums > Vehicle Tech Talk Area > Chrysler & Dodge > Transfer Case Trouble
