Subject: --Delete Thread Please--
BluecollarUser is Offline
02/26/2008 9:16 AM
thanks for your help
sammy 87User is Offline
02/26/2008 1:15 PM
i bet superlift or 4wheelparts could get you some shocks i bet superlift would have them since they have lifts for the gov dodges id use a 1tons shocks since most the gov dodges are 5/4 tons 60 rear and 44 front. my dads has motorcraft shocks that it came with when we bought it il bet any 3/4 1ton shocks will fit now that i think about it.
02/27/2008 3:08 PM
thanks. would you reccomend any shock or brand specifically?
02/27/2008 7:03 PM
Well... if money is no object, then you could get some really nice bypass shocks from King or Fox. :)
If you can afford about $800, you can get yourself a great set of adjustable, reservoir shocks from Walker Evans (I run these and LOVE them - you can see them at: http://www.4x4review.com/discussions2/topic.asp?TOPIC_ID=4653).
If money is tight, then get a decent set of MONOTUBE shocks from any reputable manufacturer like Superlift, Rancho, etc. - most are made by the same companies anyhow (Tenneco, etc.).
A few years ago, I did an article which outlines all of the different types of shocks, which you can see at: http://www.4x4review.com/feature/shock-genius.asp
hope that helps, Rick
02/28/2008 5:00 AM
thanks for the help webby...but I cant get your second link to work
02/29/2008 3:10 PM
monroe shocks from like napa autozone or advance ect monroe have been around for a while i think they have a life time warrenty or somthing like that.
03/01/2008 6:11 PM
Try it now, I fixed it. It was trying to put a period inside the link (doh!)
03/01/2008 6:13 PM
Also made by Tenneco... ;)
Tenneco makes the following brands: Monroe, Walker, Rancho, DynoMax, Clevite Elastomers, Gillet, Fonos, Fric-ROT, Kinetic, Thrush, DNX, etc...
03/03/2008 5:10 AM
okay guys, I appreciate all the advice. you have helped me narrow it down to the Monroe Gas Magnum, and the Superlift Superride Shocks. Any opinions?
03/03/2008 8:00 AM
Superlift. I've not had a lot of good luck with Monroe over the years (but that was 10 years ago, so things have likely improved).
03/04/2008 4:57 PM
the nicer thing about monroe you can pick them up at the local autoparts and superlift you have to go to 4wheelparts or order them off the internet
03/04/2008 8:02 PM
Touche', and good point!
03/11/2008 7:23 PM
okay, I recieved my shocks today, and Ive got a big question. they are stuck in the compressed position!!! and before you say, did you take the bands that keep it compresed off, yes I did. it takes force to pull it apart, but then it just gets stuck in that position. am I overlooking something or do these need returned?
03/17/2008 7:12 PM
Sorry Bluecollar - I overlooked this posting.
Any shock that is NOT a gas pressurized shock absorber will sit in one position even with the bands removed. You should be able to pull the shock piston out (wiht a great deal of force mind you), and it will then stay in that position. That is normal.
Now... if you have a gas pressurized shock and this is happening, then there is one of two issues going on: 1) The shock is just stuck a bit at the bottom of it's travel. Try hooking the end of the shock body to something sturdy (vise, tying to to a bumper, etc.), then put a large screwdriver through the eye on the piston-side of the shock. With a twisting mostion, give it a big honkin' heave-ho! and see if you can get the shock to jar loose.
2) If that doesn't work, then you have a busted shock / set of shocks. I've never seen or heard of this happening, but I have seen stranger things happen (like my wife obeying my requests, my children behaving and aliens landing in my front yard). :)
Hope that helps, Rick
Forums > Vehicle Tech Talk Area > Chrysler & Dodge > --Delete Thread Please--
