joelbra
 Bone Stock Posts:5
| 05/31/2007 7:10 AM |
| The max psi listed on my Pro Comp Xtreme AT's is 50. Should I run on the pavement at 50? Does the load in the vehicle change the PSI and change what PSI I should run at? |
primetimek5
 Lift & Lockers Posts:537
| 05/31/2007 8:57 AM |
| use the tire psi label on the drivers side door jam. is the correct
way. |
rick p. |
sublmnl1990
 Body Lift Posts:195
| 05/31/2007 6:00 PM |
| I thought that would change if you go to a different size tire due to the different cold and hot specs of the tire itself. |
primetimek5
| 05/31/2007 8:33 PM |
well, what i know you run the tire psi whats on the side of the door.
but, when i move up tire size it also depends what rateing it is (load)
on my duramax i run 60 psi cold. when you run cold it does not mean the temp.
outside. its when the tire has not been driven at all. not even around the block.
if its a dd i would put mine at least 10-15 psi under cold rating. ill get a better smooth ride out of it. if you tow a lot go w/ the cold psi.
if you can go to a cost co. or who ever has nitrogen(sp) to fill up your tires
since the air will not expand & keep your tire psi way more accurate.
in 10deg. temp. change you will lose one pound of air w/ normal air. |
rick p. |
| 06/03/2007 8:32 PM |
Hi Joelbra - here's a trick I use for every aftermarket tire I put on any of my vehicles - especially since the psi recommendations are generic and aren't specific to any given vehicle's weight...
Find a nice pad of dry concrete on a sunny day and park your truck. Take a bottle of water and pour some in front of the tires (all 4). Drive forward enough so that it leaves a track of wet tread and then inspect.
What you're going to look for is even distribution of tire tread in the track that it left behind. Always start with the tire overinflated, so that it only tracks just the center of the tread. From there, start lowering pressure in 5 pound increments until you reach a point where the track of tread is even all the way across.
At this point, you will have the optimal tire pressure for your rig's weight.
joelbra
 Bone Stock Posts:5
| 06/03/2007 10:13 PM |
Rick,
That's a very interesting way to do it -- it makes a lot of sense.
It seems odd that it's so difficult to figure these things out. If I ran the world, I'd have the manufacturers issues a chart where it tells you for each size/model of tire what the PSI should be depending on the weight/load of the vehicle. |
| 06/04/2007 11:16 AM |
| I can hear the tire-manufacturer lawyers cringing right now. :) |
sublmnl1990
 Body Lift Posts:195
| 06/04/2007 11:30 AM |
If I ran the world I would be the only one who had tires.
Well a few other would get some, maybe.
Image Uploaded To Thread: [img]http://www.4x4review.com/discussions2/uploaded/sublmnl1990/200764113159_jeep 4.JPG[/img]
| 06/04/2007 11:33 AM |
If I ran the world...
1) I'd have unlimited beer
2) I'd have unlimited sex
3) I'd have unlimited 4-wheeling
That's pretty much nirvana. [)] |
sublmnl1990
 Body Lift Posts:195
| 06/04/2007 11:39 AM |
Got this now ; To bad its solo....[V] |
| 06/04/2007 9:43 PM |
NICE! [barf2]
TMI dude... TMI!
primetimek5
| 06/05/2007 6:18 AM |
I concour. |
rick p. |
harry walker
 Bone Stock Posts:9
| 06/13/2007 6:56 AM |
way.
do u guys know anything,?we run down to 12psi,on any tyre ,just dont turn quick,orgo fast,very slow 3 point turns,allways go down beach to hard sand then turn up slowly,or invest in beadlocks.do u have driver training over there,obviosly not,.cowboys are a dieing breed becouse they DIE....&dana 44s arnt weak unless u have big hp,iran on mine far 4mths,great fun doing front burnouts,.didnt snap like twig,sold truck 3yrs later,still in there... |
tubs |
harry walker
 Bone Stock Posts:9
| 06/13/2007 7:00 AM |
depends on weight of vehicle,usualy what ever feels good,doesnt howl or wander,2ton truck needs less than 4ton,work it out..ask tyre dealer,if u trust them. |
tubs |
joelbra
 Bone Stock Posts:5
| 06/13/2007 12:18 PM |
| I did ask, yesterday and the tire dealer told me that they usually go about 10% less than the max PSI stated on the sidewall. So 45 PSI in my case. |
primetimek5
| 06/13/2007 1:23 PM |
well son, the lowest psi i run is 1 or zero psi. 20s double beedlock
46 mich. no beach cruiser here. i do that on vacation |
rick p. |
primetimek5
| 06/13/2007 1:26 PM |
way.
YES, D44 are twigs. you dont need big horse power to break these tooth pics.
oh, im sorry your in the sand. sand does not hurt. ROCKS DO!!!! |
rick p. |
primetimek5
| 06/13/2007 2:57 PM |
| dont get mad anybody. im bored at work |
rick p. |
| 06/14/2007 2:04 PM |
| Haha, I have seen our mudpits and sand pit in Alaska where I live eat Dana 44's ALIVE. And I have broken them with a stock motor with stock gears and tires. Hell, I HAVE broken a Dana 60 in the front before too. That was in mud. So whoever says that a Dana 44 is not a tooth pic, has obviously never pulled one apart and compared it to a D60 or better. Check out them tooth pick axles and ring and pinion!!!!! HAHAHAHAHA. |
