Subject: '92 Explorer 4x4 won't engage
trickyrick93312User is Offline
04/22/2005 10:34 PM
I have a '92 Explorer. The 4x4 will not engage. It makes no noise when button is pushed. I have checked the fuse marked as awd. Seems fine. Any suggestions?
BadgerUser is Offline
04/23/2005 10:22 AM
Fellow next door had that problem. It was the actuator. He had corrosion on the shaft. He said he tapped it with a soft hammer and used some lubricant on it and eventually he got it working. He cycled the 4x4 in and out a few times and it has been working fine since. Hope this helps.
Forums > Vehicle Tech Talk Area > Ford > '92 Explorer 4x4 won't engage
