Greg
 Bone Stock Posts:4
| 09/27/2005 4:44 PM |
| I've got a 97 ford explorer 4x4 i have been looking around for some type of lift for it but i cant find anything. Someone told me i could put a 3 inch ranger body lift on it. Will this work? thanks -Greg |
| 09/27/2005 5:56 PM |
How tall are you looking to go and what type of off-roading do you do (primarily)?
Greg
 Bone Stock Posts:4
| 09/28/2005 3:00 PM |
| For right now 3 inches is all im lookin and as for offroadin its usually just in mud. |
primetimek5
 Lift & Lockers Posts:537
| 09/28/2005 3:13 PM |
| YES THAT WILL WORK BUT, (I HATE WHEN THEIR IS A BUT) YOU MIGHT
HAVE TO MAKE YOUR SHIFTER LINKAGE LONGER |
rick p. |
Greg
 Bone Stock Posts:4
| 09/29/2005 6:10 PM |
| Alright that sounds good. Do you think ill be able to get any tires bigger than 31's on there?
Greg |
| 09/29/2005 7:02 PM |
Greg
Those TTB's do not lift well and can be very hard on tires, the bigger they are, the worse it gets. Stay conservative and tire size to limit problems because you will have them. |
primetimek5
| 09/30/2005 8:23 PM |
| yes sir |
rick p. |
Greg
 Bone Stock Posts:4
| 10/03/2005 5:23 PM |
| I was also thinking about puttin 2 inch coil spacers in the front and shackles in the back again using ranger parts. would this also work?
-Greg |
| 10/04/2005 5:26 AM |
-Greg
No it will not because it will through front axle camber way off and lead to funny handling and tire wear with tires running tucked in.. That axle is hinged in the middle and it must be "raised" as a unit, not with just coil spacers. |
