Subject: problems
spwalkerUser is Offline
02/09/2008 8:43 PM
ok guys, maybe someone can tel
02/10/2008 3:16 AM
IT's helpful if you tell us what year, make and model your truck is. :)
02/10/2008 10:38 AM
oh, sorry, 1994 f150 single cab 5.0L 4x4
02/11/2008 7:15 PM
Well... it sounds like you have two problems with your rig...
The first sounds like you popped a fuse or two. Have you pulled all of the fuses out and inspected them?
The second sounds like you got some water in your transmission and the clutches are slipping.
02/12/2008 7:55 PM
well, i changed the fuses out, and that was the problem, after i changed them out with new ones, everything went back to normal
thanks for the help rick!
02/13/2008 6:11 AM
boy, i tell ya.
02/14/2008 6:26 PM
That didn't fix the trans problems though, did it??? That would be weird, unless your truck has an electronically controlled lock-up converter.
02/15/2008 2:45 PM
no, it did the trans runs off of the speedometer, and once i replaced the blown fuses, the truck ran perfect.
02/17/2008 5:26 PM
Nice. Glad things worked out for you!
