thamanna
| 09/08/2010 12:39 AM |
| Tip 1: If you ain't broke, don't fix it |
| If you're lucky enough to have a new car, remember that it's covered by a three-year warranty. If you suspect something isn't right, take it into a dealer and ask them to check it out; they'll almost certainly fix it for free. This cover applies to the car, not just the original buyer, so you can make use of it even if you haven't had the car from new. And make a note of when the three years are up; the cost of extending the warranty is usually reasonable, and the peace of mind is invaluable. |
| Shop around for quotes on breakdown cover and carefully compare the level of cover you're getting - it's always a price worth paying. Getting your car recovered can be horrifically expensive otherwise, and the patrolman can often fix it for free. Remember that most policies cover you and not just your car, so keep the emergency number on your phone and not just in your glovebox. If you're a passenger when a friend's car breaks down, you can still use your policy. |
| Tip 2: Prevention is better than cure |
| Getting your car serviced regularly is the best way to avoid problems; modern cars need little attention between trips to the professionals. Not keeping your car's service history up to date can ruin its value, so find the service book, see how often it needs done and don't forget when the next one's due. |
| Tip 3: Getting your hands dirty |
| There are only three things you need to bother with under the bonnet, and they're all fluids. |
air mass meter |
