Subject: 1999 Trooper Check Trans Light
Jia_Castor___User is Offline
05/22/2003 1:35 PM
The check trans light comes on and flashes when I press the auto 4x4 button. When I depress the button, it continues to flash until I turn off the engine and restart it. The light does not come on unless the auto 4 wheel drive button is pressed. When I go into 4 wheel low, the light also stays off. The transmission seems to be running and shifting smooth. I was hoping maybe I could fix this rather than taking it to a dealer. I would apreciate anyone's help on this. Thank you for your time...
Jia Weatheford, TX
Forums > Vehicle Tech Talk Area > Misc. / All Others > 1999 Trooper Check Trans Light
