Subject: Dana Diffs
PatUser is Offline
05/16/2007 10:58 AM
wanting to know a little about a Dana 60 full floater rear and a Dana 44 closed knuckles front with drum breaks and 4:11 gears.would they make a good swap for Toyota.any feed back is helpful Thanks Pat
05/17/2007 10:02 AM
what size of tire are you gonna run? what are you gonna do w/ your truck? some toyaota axles are stout.
PatUser is Offline
05/17/2007 10:50 AM
around 38's and rock crawling might be fun.possibly put small block in it for more power.
05/18/2007 12:05 PM
are you gonna lock the front axle? if your gonna run a strong health eng. the d44 will brake like a twig. a d44 axle is not much stronger then a 10bolt. (really the same)
