heathmrktg
| 08/22/2008 12:22 AM |
Image Uploaded To Thread: [img]http://www.4x4review.com/discussions2/uploaded/heathmrktg/200882201658_yahoopic.jpg[/img]
Rising fuel costs have motorists searching for
anything that will improve vehicle efficiency.
Vehicle manufacturers, under pressure to meet
more stringent EPA regulations, are recommending
lower-viscosity oils as one way to
improve efficiency. AMSOIL 100% Synthetic
Motor Oil (ASM) features a special low viscosity
formulation that combines maximum
fuel economy with maximum wear protection.
Maximum Fuel Economy
AMSOIL Synthetic Motor Oil is designed
to maximize energy efficiency for improved
fuel economy. Its light viscosity properties
reduce drag and its uniform molecular
structure helps it fl ow more freely to lower friction
between metal surfaces. Anti-friction additives
are included to further improve energy
efficiency.
Superior Wear Protection
AMSOIL Synthetic Motor Oil is a shear
stable formulation with a high viscosity index.
It provides excellent viscosity film strength to
separate metal surfaces and contains robust
anti-wear additives for the best possible engine
protection.
Reduced Oil Consumption
and Emissions
Volatility (burn-off) occurs when oil gets hot,
causing high oil consumption and emissions.
AMSOIL Synthetic Motor Oil has a very
low volatility rate, making it excellent at controlling
volatility-related oil consumption and
emissions.
Extreme-Temperature Performance
AMSOIL Synthetic Motor Oil resists thermal
breakdown better than conventional
oils. It is heavily
fortified with detergent and
dispersant additives to
prevent sludge deposits
and keep engines
clean. And unlike conventional oils,
AMSOIL contains no wax.
It stays fluid down to -65°F for improved
cold-temperature oil flow, reduced bearing
wear and easier starting while maintaining
superior high-temperature protection.
Request you free information
http://www.allpurposeoil.com |
Mobil1 Vrs. Amsoil
Click HERE to find out the Truth
