Subject: Rockcrusher New Diff Cover: Chrysler-Jeep 8.25
LarryConvilleUser is Offline
12/01/2008 11:17 AM
Rockcrusher 8.25 Differential Cover
The strength and durability of these Rockcrusher diff covers (diff hats in Australian) are absolutely the strongest and most durable units on the market to date. Rockcrusher covers are .250” thick with reinforcement ribs. The larger diameter oil fill hole is located higher on the cover to aid in filling rotated housings. Includes mounting bolts, fill plug, and easy to follow installation instructions.
FITS These Applications:
○ Dodge 1/2 Ton Pickup: 1970-2006 (Rear)
○ Dodge 3/4 Ton Pickup: 1970-2001 (Rear)
○ Dodge Dakota Pickup: 1988-2005 (Rear)
○ Dodge Durango: 1998-2004 (Rear)
○ Jeep Cherokee XJ: 1991-2001 (Rear)
○ Jeep Cherokee XJ Sport: 1991-2001 (Rear)
○ Jeep Grand Cherokee WJ: 1992-2001 (Rear)
○ Jeep Liberty KJ: 2002-2006 (Rear)
Why You Want It…
• Heat Treated 100% Ductile American Steel Casting for Strength.
• Provide Extra Oil Volume to Keep Gears Cooler for Longer Life.
• Reinforced Ribbed Design Helps Dissipate Heat & Provides Rigidity & Extra Protection.
• Recessed Bolt Seats for a Premium Surface Mounting Contact.
• Exclusive ‘FLAT FIT’ Fully CNC Machined Gasket Surface Seals Properly with No Leaks.
• Uses Standard Seals That Are Available at Any Auto Parts Store.
What You Get…
• A Quality, Extremely Well-Built, Super Beefy Differential Cover
• Quality High-Grade Hardware and H-14 Hex Bit Fill Plug
• A Far Superior Product over Factory Stamped Covers and Other Competitive Models
• Improved Protection for Your Differential
• Security for Your Time & Investment
• Hassle Free Installation
• No Leaks or Drips in Your Driveway
• Peace & Mind Knowing that Your Worthy Investment Is Protected
• Lifetime Warranty – If you break it and you’re still breathing, Rockcrusher will gladly replace it at No Charge.
Part Number: 18250... Diff Cover
Chrysler-Jeep 8.25 Inch
Lox4RoxUser is Offline
12/01/2008 10:50 PM
Do you have pricing available on these applications yet?
Also, do you have dates on when the Dana applications will be available? Such as the Dana 44, Dana 60, etc.
Lastly, do you have any pictures?
thanks
John Reader - '79 Jeep CJ, '74 Ford Bronco
12/02/2008 10:21 AM
The re-established Rockcrusher does not sell directly to the public any longer. Pricing is only available through Rockcrusher's dealer network.
The prices start at $115 per cover. NOW until December 28th, many dealers are offering FREE SHIPPING!.
http://rockcrusherdiffs.com/dealers.html
You can see pictures of the covers at these dealer's sites...
http://4wheelonline.com/Categories.aspx?CategoryId=92726
http://motionoffroad.com/catalog/index.php?main_page=index&cPath=129_130
http://rockymountainsusp.com/differential_cover.htm
http://www.ntwonline.com/Rockcrusher_Differential_Cover_C1002.cfm
These Rockcrusher Diff covers are ready to Ship NOW!
• # 11400 - Diff Cover Chevy/GM 14 Bolt
• # 11025 - Diff Cover Ford 10.25 Inch-Sterling
• # 18250 - Diff Cover Chrysler-Jeep 8.25 Inch
• # 19250 - Diff Cover AAM 9.25 Inch
• # 11050 - Diff Cover AAM 10.5 Inch
• # 11150 - Diff Cover AAM 11.5 Inch
• # 18800 - Diff Cover Ford 8.8 Inch
These Rockcrusher Diff Covers will be Available December 28th...
• # 13500 - Diff Cover Model 35
• # 13000 - Diff Cover Dana 30
• # 14400 - Diff Cover Dana 44
• # 16000 - Diff Cover Dana 60
Thanks for the request. Let me know if you need anything else or have any other questions.
LarryConville
Forums > Vendor Showcase > Drivetrain (Engine, trans, t-case, axles) > Rockcrusher New Diff Cover: Chrysler-Jeep 8.25
